• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    DRAWING VIEWS
    221 Views, 7 Replies
    08-29-2012 12:59 PM
    I am still making some adjustments to our standard drawing template and I ran into another issue I need some help with.
    I want the tangent edges to be displayed automatically when I insert a drawing view rather than clicking the Display Options tab and checking the Tangent Edges box every time I make a new drawing.  Is this possible?  If so, how?
    I tried inserting a view, checking the Tangent Edges box, then deleting my view and re-saving the template but it still went back to the default.
    Please use plain text.
    Curtis_Waguespack
    Re: DRAWING VIEWS
    08-29-2012 01:27 PM in reply to: avaya2012
    Hi avaya2012,
    This ability has been requested in the past (going back to at least 2003), but I'm not aware of any updates to Inventor that allow you to accomplish what you're asking for at this point.
    http://forums.autodesk.com/t5/Autodesk-Inventor/interference-and-tangent-edges-default-to-show-on/m-...
    You can request enhancement and new features using the Feed Back link:
    http://inventortrenches.blogspot.com/2011/01/feature-request-for-inventor.html
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Active Contributor
    Re: DRAWING VIEWS
    08-29-2012 01:38 PM in reply to: Curtis_Waguespack
    Well I guess it helps me to the point that I won't waste any more time trying to figure this out.
    It sure seems like Inventor does not like to add or fix little issues like this.
    *Pro
    jletcher
    Re: DRAWING VIEWS
    08-29-2012 01:46 PM in reply to: avaya2012
    It was better when Inventor 1st came out they was ontop of it tying to fix everything they could with patches they listen to the users . But now they have you stuck once you go inventor and get parts made it is hard to tell the owner of your company Inventor was a mistake lets buy this..
    I wish I knew where Autodesk fell off the tracks I would go help them get back on it...............
    But hey it keeps clients calling me...............
    and 2013 and all the new crap has my phone ringing off the hook :smileyhappy:
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    Distinguished Contributor
    JimSteinmeyer
    Re: DRAWING VIEWS
    08-29-2012 02:26 PM in reply to: jletcher
    You mean I don't want to upgrade yet? :smileyvery-happy:
    A related question. I would like to have the views placed showing part number rather than view number. I know how to make it show the part number if I manually change it bit it gets tedious for every view.
    Thank you
    Jim
    Inventor Premium 2013 SP1.1
    Vault 2013- plain vanilla version
    HP G71 notebook
    celeron cpu w\ 4gb RAM and 64 bit system
    Win 7 home premium
    Ya, my boss has me running my personal machine at work.
    Curtis_Waguespack
    Re: DRAWING VIEWS
    08-29-2012 03:05 PM in reply to: JimSteinmeyer
    Hi JimSteinmeyer,
    That request can be accomplished. :smileyhappy:
    From a drawing, go to the Manage Tab > Styles Editor button, and then select your Standard, and set the View Preferences tab active. Then use the Edit View Label button as shown.
    I hope this helps.
    Curtis
    JimSteinmeyer
    Re: DRAWING VIEWS
    08-30-2012 12:33 PM in reply to: Curtis_Waguespack
    Thank you Curtis! I assume I need to do this to my template in order for this to take effect for every drawing. This will save me vast ammounts of time. Now if we coulod just get Invenrot to reccognize assembly components with a balloon when placed as an individual part, but I suspect it has something to do with the way bills of materials are devised and won't work.
    Jim
    HP G71 notebook
    Win 7 home premium
    karthur1
    Re: DRAWING VIEWS
    08-31-2012 06:07 PM in reply to: avaya2012
    Jim,
    You need to to that to your template and then save it to your styles library.
    "... Now if we coulod just get Invenrot to reccognize assembly components with a balloon when placed as an individual part,..."
    Not sure if I follow you there. Can you expand on this a little?
