• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    DEFAULT SYMBOL IN EDIT DIMENSION TEXT DIALOG
    203 Views, 5 Replies
    11-29-2006 11:05 AM
    LOOKING FOR A WAY TO MAKE THE DIAMETER SYMBOL THE DEFAULT SYMBOL INSTEAD OF THE DEGREE SYMBOL IN THE SYMBOL DROP DOWN ON THIS DIALOG BOX:
    DIMENSION EDIT>TEXT TAB
    SEE THE ATTACHED SCREENSHOT
    Work Station : Dell Precision R5400
    OS: Windows 7 Business 64 Version 6.1.7601 Service Pack 1 Build 7601
    Processor Intel(R) Xeon(R) CPU E5405 @ 2.00GHz, 1995 Mhz, 4 Core(s), 4 Logical Processor(s)
    BIOS Version/Date Dell Inc. A05, 7/15/2010
    Graphics Display Card: NVIDIA Quadro NVS 290 (256MB RAM)
    Memory: 8 GB
    Please use plain text.
    *Lati Mu \(Autodesk\)
    Re: DEFAULT SYMBOL IN EDIT DIMENSION TEXT DIALOG
    12-05-2006 06:33 AM in reply to: sgwilliams
    You are not able to change the default symbol in the Edit Dimension dialog.
    However you can create a new dimension style with the diameter symbol as a
    prefix.
    Lati Mu
    Inventor QA
    Member
    09-03-2012 05:33 AM in reply to: sgwilliams
    Please CHANGE that!!! The need of DIA symbol is greater than DEG symbol. THINK!
    Regards
    Adrian
    Employee
    09-07-2012 06:19 AM in reply to: a.sima
    Hi Adrian,
    there is logged withlist item for this requirement (#1087837).
    Ladislav
    Member
    12-19-2012 07:14 AM in reply to: t_pcoll
    Sound really good.
    An additional proposal is to have the dimeter, the degree and the +/- symbol as shortcut buttons just under the button that opens the symbol list. This way it is easy and quick to choose the three most used symbols applied in the text.
    Regards
    Bo
    Distinguished Mentor
    ampster
    12-19-2012 08:08 AM in reply to: boyebusk
    screenshot from Inv 2011, looks like your request is already present, at least those three symbols are at the very top of the selections.  May not be exactly what you wanted though I'll admit that.
