• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Accepted Solution
    Cutout appearance doesn't work
    506 Views, 15 Replies
    09-20-2012 07:03 AM
    I have a problem when I want to use a cutout.
    My purpose is to get a perforated plate but Inventor doesn't show this.
    Only the black color is shown and not the holes.
    What am I doing wrong?
    Thanks in advance
    Nick
    Please use plain text.
    *Expert Elite*
    Cadmanto
    Re: Cutout appearance doesn't work
    09-20-2012 07:09 AM in reply to: nick.jeuris
    Make sure the "cut" is selected in the command dialog window.
    I can't open your file because I am still on 2012.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    Distinguished Mentor
    ampster
    09-20-2012 07:26 AM in reply to: nick.jeuris
    if you're just using that .png file to similate perforated plate, the cut away won't work.
    Active Member
    09-20-2012 07:30 AM in reply to: Cadmanto
    Hi Cadmanto
    I'm not doing an extrude, but I am using the cutout option in the appearance menu.
    See the screenshot in attachment.
    Nick
    Active Member
    09-20-2012 07:32 AM in reply to: ampster
    What's wrong with the .png file?
    *Expert Elite*
    mrattray
    09-20-2012 07:55 AM in reply to: nick.jeuris
    I'm not sure what you did wrong, but after I cleard your overrides and set generic to use your image file it worked fine.
    Mike (not Matt) Rattray
    *Expert Elite*
    Cadmanto
    09-20-2012 07:59 AM in reply to: nick.jeuris
    Sorry I misunderstood your issue.
    2 thoughts, first maybe the transparency needs to be adjusted on the png file
    and second, can you use this appearance in the color portion of the style and standard editor?
    Best Regards,
    Scott McFadden
    *Expert Elite*
    mrattray
    09-20-2012 08:01 AM in reply to: Cadmanto
    You forgot that there are no longer colors in 2013. He has to work with the appearance editor.
    *Expert Elite*
    09-20-2012 08:06 AM in reply to: Cadmanto
    ..... Styles and Standards, Materials and Colors questions based on 2012 and earlier releases.
    It has all changed in 2013.
    *Expert Elite*
    Cadmanto
    09-20-2012 09:20 AM in reply to: mrattray
    Alrighty then...:smileyfrustrated:
    I am still on 2012, so I guess I have something to look into.
    Thanks for the heads up guys.
    Best Regards,
    Scott McFadden
