• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Anthony
    Accepted Solution
    Cut angle section out of circular hollow tube
    254 Views, 4 Replies
    12-05-2012 03:53 AM
    I have a small section of hollow tube as an IV part which I need to cut to at one end to produce a tapered effect. Attached is a mark up of what I am trying to achieve with the hollow tube. Does anyone have a solution for this ? Thanks
    Inventor 2013 Product Design Suite Ultimate
    Windows 7 Professional-64Bit 12GB RAM
    Intel Xeon W3550 3.07GHz
    Please use plain text.
    *Expert Elite*
    Re: Cut angle section out of circular hollow tube
    12-05-2012 05:05 AM in reply to: Anthony
    Attach the ipt file here.
    Unless I am missing something - it should be a simple Split, Extrude-Cut or Sculpt.
    Inventor Professional 2014 Edu 64-bit
    Anthony
    12-05-2012 07:05 AM in reply to: JDMather
    Sorry for the bad wording on my post, what I forgot to add was that I had attempted this using workplanes but found it a lot easier to simply create 2 sketchs with the desired taper angle on the tube end and split the solid. Thank you for the reply.
    *Expert Elite*
    12-05-2012 07:19 AM in reply to: Anthony
    No workplanes are needed.
    Simply a sketch with 2 connected lines to do the Split.
    Anthony
    12-05-2012 07:25 AM in reply to: JDMather
    Many thanks, yes I found the split method to be the most effecive. :smileyhappy:
