• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Accepted Solution
    Custom title block placement
    203 Views, 3 Replies
    09-18-2012 12:07 PM
    Creating a custom title block in innventor seems to be straight foward however when I save the new title block it offsets from the sheet, up and to the right. How do I get the title block to line up with the sheet
    Bill
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: Custom title block placement
    09-18-2012 03:17 PM in reply to: brankin
    Hi brankin,
    Depending on your situation, you can likely fix this by going to the Tools tab > Application Options button > Drawing tab. You'll see the option to control the title block insert point there.
    Or you might just need to specify your insert point in the sketch:
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    *Expert Elite*
    mrattray
    09-19-2012 04:55 AM in reply to: brankin
    Do you have a seperate border? I find that having an appropriate border helps with titleblock placement for some odd reason.
    Mike (not Matt) Rattray
    Member
    09-19-2012 07:44 AM in reply to: Curtis_Waguespack
    Thanks Curtis.....that was the problem
