• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Custom profile trim to frame error
    207 Views, 7 Replies
    11-14-2012 11:19 PM
    Hello all.
    At my company we have a custom CC library with custom profiles for use in frage generator. We are having a problem with one of the frames. Everything goes well when the profiles is inserted.
    But when I try to "trim to frame" the intersections of two profiles, it does not trim them correctly. It trims them in a 45 degree angle. As you can see on the attached jpg file.
    I tryed everything. Checked the sketch, deleted the profile, republished the part. I am out of ideeas. We have more profiles like this, but we do not have this problem with them.
    I attached a CC library with this profile in it. Can you please take a look at it. Maybe somebody can figure it out.
    Thanks.
    Inventor 2010
    Win 7 64-bit
    Dell Precision T5400
    Intel Xeon 2,5 GHz
    8 Gb RAM
    NVIDIA Quadro Fx 3700
    Please use plain text.
    cbenner
    Re: Custom profile trim to frame error
    11-15-2012 05:38 AM in reply to: SoulAsasin
    This may be a dumb question, but are you sure that in the trim it is not selecting one of the angled faces as the trim face?  Maybe try using Trim/Extend on this one, and manually select one of the angled faces, and then again with one of the perpendicular faces... might help you diagnose if that's what is happening in the Trim to Frame.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Active Contributor
    11-15-2012 10:20 PM in reply to: cbenner
    Hey.
    Thanks for the reply. I am sure that the trim to frame is selecting one of the angled faces as trim surface by default. But, I want to know why, because this is not normal. We have more than 25 this kind of profiles, all published by me, and we do not have this problem.
    Trim/Extend works ok, but it would be great if trim to frame would work as welll, becasue it trims both of the profiles, and this helps on productivity.... somethimes.
    Thanks anyway.
    Inventor 2010
    Win 7 64-bit
    Intel Xeon 2,5 GHz
    8 Gb RAM
    Member
    04-24-2013 10:46 AM in reply to: SoulAsasin
    Did you ever get a solution for this??
    Active Contributor
    04-24-2013 10:10 PM in reply to: dtrappe
    Hey.
    Are you experiencing the same problem?
    No. Unfortunatly I did not find a solution or explication for this...
    Inventor 2010
    Win 7 64-bit
    Intel Xeon 2,5 GHz
    8 Gb RAM
    blair
    04-25-2013 09:08 AM in reply to: SoulAsasin
    Wouldn't the "Miter"work for this?
    I remember a couple of versions back, the F-G would through hickups on some stuff I did. Seemed to improve over the last number of releases.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Member
    04-25-2013 12:37 PM in reply to: SoulAsasin
    Yes,
    It lools like exactly the same thing.
    Made a bunch of 8020 profiles, and about half the time it does the thing that you have in your pictures and at other times, it behaves fine.
    Seems to be no rhyme or reason, although there must be something.
    Seems to be more problematic on more complex profiles, so I wonder if it is trying to trim to one of the interior portions of the extrusion.
    Trimming to face would work I think, but there are so many faces on the 8020 stuff that is is really immpractical.
    I have been just shortening the lengths as a work around, but the trim functionality would really be faster.
    Active Contributor
    04-25-2013 10:14 PM in reply to: dtrappe
    Hy
    i am asure that IV somehow considerres an inner surface as the trim surface. The strange thing is that I made about 25 such custom frame profiles like this, with similar forme. This is the only one that has problems.
    I am using trim trim/extend instead of trim to frame.
    Inventor 2010
    Win 7 64-bit
    Intel Xeon 2,5 GHz
    8 Gb RAM
