• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Custom iProperties not updating in drawing when I update assembly model
    124 Views, 2 Replies
    11-19-2012 07:51 AM
    I'm using Inventor 2011 and when I go to change parameters using iLogic in an assembly model, (sometimes it is a component suppression, other times it is an iPart component change) it won't update the associated drawing file. I need to go into the BOM on the drawing and renumber the balloons, or change something else in order for the custom iProperties to update in the drawing template. If I just change the iPart component, then the BOM doesn't need to update making the renumbering of balloons redundant.
    I'm using iLogic to update all of the iProperties and component references, then reattach balloons. What I would like to do is automatically update the custom iProperties drawing template fields, and renumber the drawing BOM. Does anyone know how to do this?
    Please use plain text.
    New Member
    Re: Custom iProperties not updating in drawing when I update assembly model
    11-19-2012 08:38 AM in reply to: cmp78
    So I've fixed the custom iproperties by just adding a small save
    ilogicvb.updatewhendone=true
    thisdoc.save
    I'm still having trouble getting the BOM to update and renumber..
    *Expert Elite*
    Cadmanto
    11-20-2012 06:19 AM in reply to: cmp78
    Have you tried doing a complete rebuild to see if that will spark the change?
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
