• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    SkipAB
    Custom iParts location
    208 Views, 2 Replies
    09-07-2011 09:15 AM
    When you read Inventor 2011 Help topics and tips about iPart/Custom iPart file locations or pathways, does Inventor assume you are using Vault?
      We do not use Vault.  I am able to get parts from a regular iPart factory to go into a folder that is specified in the projects library tab, but I am not able to get custom iParts to go into a folder set as a proxy path (it has the underscore in front of the folder name).  The parts created from a custom iPart factory always go into the folder where the active project is located???
    Please use plain text.
    Employee
    Re: Custom iParts location
    09-09-2011 01:39 AM in reply to: SkipAB
     The active project setting provides the default location for custom iPart member. The destination location and filename also can be changed in the Place Custom iPart dialog.
    Leo Xie (Lichao.xie@autodesk.com)
    Software Engineer, Inventor
    Manufacturing Group
    Member
    05-03-2012 12:37 PM in reply to: SkipAB
    Is there a way to force custom Iparts to save into a specified folder rather than in the folder containing my project folder?
