Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Custom iPart Problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I need to make a custom iPart. I know how to use iParts but I am having trouble with this one. When
I place this custom iPart in my assembly it comes in as "Part3.ipt" which is not the correct name. I
need to name this a part number like 7-55545-002 instead of "Part3.ipt". How can I get the Custom
iPart factory to ask me to "name" the part. I have already made the filename a "key" in the table
but it does not prompt me. What should I do?
Re: Custom iPart Problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
filename. It will always ask you and will default o the next default part
name (e.g. part1, part2 etc..)
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.c
...sleep is for the
weak..
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"mmiller" <Hi
href="mailto:mmiller@genlytethomas.com">mmiller@genlytethomas.com>
wrote in message
href="news:f124db8.-1@WebX.maYIadrTaRb">news:f124db8.-1@WebX.maYIadrTaRb...
Group,
need to name this
Custom
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
window of the table and add filename
to filename<filename></filename>
add the appropriate info in that column
subject
Ole Germer
Helping create better involute profiles for
gears
href="http://www.geocities.com/olegermer/index.htm
"mmiller" <Hi
wrote in message
Group,
need to name this
Custom
Re:
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
missing something you cannot specify a filename with Custom iparts (where one
parameter is left to be specified by the user) e.g. one of the structural
channel iparts..
Sean Dotson, PE
...sleep is for the
weak..
"Ole Germer" <
href="mailtole.germer@sympatico.ca">ole.germer@sympatico.ca> wrote in
message
href="news:16A4A7D886F1A2C89E43834F6894ACCC@in.WebX.maYIadrTaRb">news:16A4A7D886F1A2C89E43834F689......
the way to do it is to add filename in the last
now go to the excel sheet and change the filename
that should fix it -- of course you will have to
Sean has some good tutorials on the
subject
Ole Germer
gears
href="http://www.geocities.com/olegermer/index.html">http://www.geocities.com/olegermer/index.htm...
"mmiller" <Hi
wrote in message
Group,
need to name
the Custom
should I do?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Simply click on it, give your part a name and make sure it is pointed to the right
directory.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"mmiller"
> Hi Group,
this one. When
correct name. I
the Custom
the table
> Thanks,
Re:
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
about Custom iParts. Now if I can remember to do that instead of clicking
through so fast.
K
"Kent Keller"
news:44F9F0B518B94757B27647963AC0BAD2@in.WebX.maYI
> Just to add .... when you place the part in the dialog notice there is a
Browse button.
the right
> directory.
> Kent
> "mmiller"
> > Hi Group,
trouble with
> this one. When
which is not the
> correct name. I
How can I get
> the Custom
filename a "key" in
> the table
> > Thanks,
