Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Custom Multi-Valu e Menu in Drawing iPropertie s
- Highlight
- Email to a Friend
Does anyone know how to make a multi-value drop down menu in drawing iProperties?
I want to make a list with aluminum extrusion sizes where I can pick it's name from a list of names. Similar to the custom iProperties "Design State".
Thanks.
Re: Custom Multi-Valu e Menu in Drawing iPropertie s
- Highlight
- Email to a Friend
easy enough to make an ilogic rule to populate a custom iproperty field from a predefined list.
First open your drawing template. Go to the custom tab of the iproperties and add a new iproperty named EXTRUSION
Then create a new ilogic rule (manage tab..ilogic section..add rule button) in your drawing template file and copy/paste the code between the asterisks below into that rule.
You modify/add the "Extrusion Type 1" to be whatever you want like .. You can add more than 3 or whatever..
'Requires a custom iProperty called "EXTRUSION" already defined in your drawing iproperties.
Dim CExt As New ArrayList
CExt.Add("Extrusion Type 1")
CExt.Add("Extrusion Type 2")
CExt.Add("Extrusion Type 3")
iProperties.Value("Custom", "EXTRUSION") = InputListBox("Select the extrusion type", CExt, iProperties.Value("Custom", "EXTRUSION"), Title := "Extrusion", ListName := "Extrusion")
iLogicVb.UpdateWhenDone = True
2012 Product Design Suite Ultimate
Windows 7 64 bit
90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
- Highlight
- Email to a Friend
Hi jbauer,
I'll add to mcgyvr's iLogic rule and suggest a Try/Catch to create the custom iProperty for you (if it's not found). The rule can then be created as an external rule and triggered on any appropriate part, without the need to setup the custom iProperty first.
I hope this helps.
Curtis
'define the custom property name
Dim propertyName1 As String= "EXTRUSION"
'create a list of values
'define an input list and get the user selected value from the list
Dim sInput as String
sInput = InputListBox("Select the extrusion type", CExt, CExt.Item(0), "iLogic", "Extrusion")
Try
'set the custom property value
iProperties.Value("Custom", propertyName1) = sInput
Catch
' Assume error means the property was not found
'define custom property collection
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
'create the custom property
oCustomPropertySet.Add("", propertyName1)
End Try
- Highlight
- Email to a Friend
Nice Curtis
Clearly I'm an ilogic newbie..but you've got to start somewhere.. I will be adding that to my code.. Just last week I was getting annoyed because I had some old models that didn't have the custom props already assigned (its in my template files now) and kept having to go and add them.
ooo.. didn't notice we had an "Insert code" function on this board either..
Windows 7 64 bit
- Highlight
- Email to a Friend
Thanks for the code. It works great. Is there a way the code can be made a multiple value? There are times when I may have 2 or more types of extrusion in a drawing.
Thanks again.
- Highlight
- Email to a Friend
Hi jbauer,
Something like this maybe?
I hope this helps.
Curtis
Dim propertyName1 As String= "EXTRUSION_A"
Dim propertyName2 As String= "EXTRUSION_B"
Dim CExt1 As New ArrayList
CExt1.Add("Extrusion Type 1")
CExt1.Add("Extrusion Type 2")
CExt1.Add("Extrusion Type 3")
Dim CExt2 As New ArrayList
CExt2.Add("Extrusion Type 4")
CExt2.Add("Extrusion Type 5")
CExt2.Add("Extrusion Type 6")
Dim sInput1 as String
sInput1 = InputListBox("Select the extrusion type", CExt1, CExt1.Item(0), "iLogic", propertyName1)
Dim sInput2 as String
sInput2 = InputListBox("Select the extrusion type", CExt2, CExt2.Item(0), "iLogic", propertyName2)
Try
iProperties.Value("Custom", propertyName1) = sInput1
Catch
End Try
Try
iProperties.Value("Custom", propertyName2) = sInput2
Catch
oCustomPropertySet.Add("", propertyName2)
End Try
