• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *B, Tim
    Custom Machine
    29 Views, 4 Replies
    12-06-2002 08:36 AM
    Looking for advice on how to set up a design for a custom machine. I have a
    custom machine that has a variable infeed and a variable discharge for each
    job release. Basically the machine has a round 100 parts and for each job
    release about twenty five parts will change each time. The twenty five
    parts will always be different. Any suggestions on how I should do this.
    Tim
    Please use plain text.
    *Caldwell, Larry
    Re: Custom Machine
    12-06-2002 09:30 PM in reply to: *B, Tim
    I guess you'd probably have to change the 25 parts! Are you implying
    that there is an infinite variation of parts, i.e. could be anything someone
    dreams up or is there a limited number of configurations for whatever goes
    in and out? If there is a limited number of configurations that are
    different but similar you could make custom iParts. Other than that you
    could probably make a template and start with that.
    ~Larry
    "Tim B" wrote in message
    news:010694D9851E909739E9062EDD8F34A7@in.WebX.maYIadrTaRb...
    a
    each
    > Tim
    *B, Tim
    Re:
    12-06-2002 09:39 PM in reply to: *B, Tim
    How could I handle the idw drawings that must have a new drawing numbers
    each time.
    "Larry Caldwell" wrote in message
    news:5FD4B1838DCE98D498EFEED63B1C9C0D@in.WebX.maYIadrTaRb...
    someone
    > ~Larry
    have
    > a
    > each
    job
    this.
    > > Tim
    *Dotson, Sean
    Re:
    12-06-2002 11:11 PM in reply to: *B, Tim
    Get to become real good friends with Design Assistant. Read the online help
    to get started then this NG for more info.
    Sean Dotson, PE
    http://www.sdotson.com
    Check the Inventor FAQ for most common questions
    www.sdotson.com/faq.html
    news:46A66D2D31E17D024DA66540A2598388@in.WebX.maYIadrTaRb...
    > each time.
    > someone
    goes
    > > ~Larry
    > have
    > > a
    > > each
    > job
    five
    > this.
    > > > Tim
    *Gralinski, James
    Re: Custom Machine
    12-08-2002 10:15 PM in reply to: *B, Tim
    Tim,
    Make the parts that do not change reference parts.
    They will not show up in the BOM's and will have phantom lines in .idw
    files.
    Hope this helps
    Jim
    ERG
    a
    each
    > Tim
