• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Cross Hatch
    566 Views, 8 Replies
    08-24-2012 02:44 PM
    I have an assembly that is made up of steel and brass parts.  I have assigned the material in each part but when I cross section the assembly in a drawing all sections use the ANSI32 section style.  I can't find a way to tell Inventor to use a cross hatch based upon the part material.  Am I blind or is this not possible?
    Stuart Kinzel
    Inventor 2013-64bit, HP EliteBook8740w Intel Core i5CPU 2.67 GHz
    8GB memory
    Windows 7 64bit
    Please use plain text.
    blair
    Re: Cross Hatch
    08-24-2012 03:13 PM in reply to: SKinzel
    Just RMB on the hatch and select "Edit", select the appropriate material from the Pattern drop-down menu.
    Not b\y default, you must make the change yourself. All you get is the ability to select the default Hatch from the Styles Manager.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.0 / 4.11
    Re: Cross Hatch
    08-24-2012 03:16 PM in reply to: blair
    That is what I ended up doing but it seems to me that if I assign a material to an IPT then the cross hatching of a drawing should recognize that and use that as a basis for what cross hatch pattern is used.  I was just suprised that Inventor doesn't seem to be able to determine what cross hatch pattern to use based upon the material property.
    Stuart Kinzel
    8GB memory
    Windows 7 64bit
    Employee
    Xun.Zhang
    Re: Cross Hatch
    08-26-2012 10:45 PM in reply to: SKinzel
    Hi Kinzel,
    Please ues Style Editor for cutomerize for the first time or save the style to a template, then you could get the hatch by materials assigned.
    Steps:
    1. Open Style Editor in a blank Draing.
    2. Select the Stardard style which in use.
    3. Tab "Material hatch patten default" to change the Default hatch for each Material.
    4. Save the style.
    Xun Zhang
    Software QA Engineer
    Inventor Quality Assurance Team
    Re: Cross Hatch
    08-27-2012 05:11 AM in reply to: SKinzel
    Thank you.  This is what I was looking for.  I am a little suprised that this isn't set up as default so that different materials will use the "defined" cross hatch patterns.
    Stuart Kinzel
    8GB memory
    Windows 7 64bit
    Valued Contributor
    Mike686
    Re: Cross Hatch
    11-09-2012 08:26 PM in reply to: SKinzel
    hi, i've been wondering if there's a way to tell inventor to place the angle of an hatch patern parallel to a line..
    i'm doing glass panel and when i do a section of it i wish to see the line parallel to the panel
    i want the result to look like the pdf file i've joint
    is it possible and if yes how would i do that
    Product Design Suite 2013
    Re: Cross Hatch
    11-10-2012 05:45 AM in reply to: SKinzel
    Are you assigning Materials (physical properties) or are you assigning colors/textures with material names?
    Re: Cross Hatch
    11-16-2012 02:29 PM in reply to: JDMather
    In 2013 I open the Material Browser and assign a material to the model.  I've assigned different colors to different matierals to help me easily remember what is made out of what.  Plus, looking at a monochrome assembly model is boring.  I just thought it was a little strange that by default Inventor seems to use the ANSI 32 hatch pattern for almost all of the materials.  On a drawing one of the quickst and easiest ways to differentiate materials is by their cross hatching.  Inventor 2011 was the same as I recall.
    I was taught that the hatch pattern for steel looked like ANSI 32 and that aluminum (ANSI 38), iron (ANSI 31) and other materials used other patterns.  Maybe that isn't specified in any actual, official drafting standard?  My drafting classes have been so long ago that maybe I am misremembering and I just incorporated one company's rule of thumb into my personal preferences.
    Stuart Kinzel
    8GB memory
    Windows 7 64bit
    blair
    Re: Cross Hatch
    11-16-2012 03:04 PM in reply to: SKinzel
    If you check the Styles Manager, you will find that someone at Autodesk has ANSI31 set for all the material (I hope that this was an oversight or possibly some programmers last work day at Autodesk).
    Win7-64
