• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    jamesdowner
    Creating own tube and pipe style
    331 Views, 2 Replies
    10-10-2012 04:22 AM
    Currently running inventor 2013 premium still on the free trial until it runs out and i register it.
    I am trying to create my own tube and pipe style for a 22mm copper heating pipe run.
    I have been through and created the parts and successfully published them into a user contents library.
    I start a new tube and pipe run in an assembly. then go manage>tube and pipe styles
    I then hit 'New' i fuill out the details, select my pipe, bend and coupler...everything seems ok, i hit save.
    it doesnt appear in the styles selection menu to the left (where it should and did on the tutorial) and whats more when i try and exit or do anything else the 'Save Edits?' warning comes up (clicking save doesnt help)
    This is the second tube and piping run in this assy. but is a whole new run rather than route.
    Any ideas?
    is it a bug? or lack of privelages?
    regards
    James
    Please use plain text.
    Active Contributor
    Re: Creating own tube and pipe style
    10-22-2012 08:00 AM in reply to: jamesdowner
    I have a similar problem.
    I copy a pipestyle using "Content Center Editor" and rename it. Then alter the material and save it.
    I then create a new pipe style using "Tube & Pipe Styles". However, when I double click "Pipe" to add the new style there is no plus symbol next to the new style and I'm unable to choose it.
    If I go through the same process for an elbow then all is well. Just for pipes.
    Inventor 2013
    *Expert Elite*
    10-22-2012 09:42 AM in reply to: jamesdowner
    James--
    I had some similar issues when I was first learning to set up the Tube & Pipe module.  I have attached a document that details some of these issues and what I did to fix (or work around) them.  It sounds like the trouble you are experiencing is similar to what I described in part 1 of the document.
    Hopefully this helps.
    sbromley--
    It sounds like you are having a different issue, so you really should have started a new thread.  But check the filters in the selection dialog.  You may have a filter that is excluding your copied pipe style.
