• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Cadmanto
    Re: Creating iparts from Content Center
    06-08-2012 12:07 PM in reply to: Curtis_Waguespack
    Curtis,
    Your first series of bullet points is what I will try believing what you are saying that if I was to republish the iparts (originally copied from CC) back into CC would allow me to switch iparts from the factory within the assembly it is inserted into.
    Your second point is correct.  That is my opriginal question.
    You can create a part from scratch.  Create iparts from the factory.  Then insert that into an assembly and change it like you showed in your image.  But when you do a save as copy of a CC part and do the same process, it doesn't work.  Why?
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    Please use plain text.
    Curtis_Waguespack
    06-08-2012 12:19 PM in reply to: Cadmanto
    Hi Cadmanto,
    Re: the original question
    Opening a part from CC, saving a copy of it, and then making that file an iPart factory, should allow you to use Change Component just like any other iPart. In fact the screen shot I showed was from an iPart that I created following just those steps.
    Re: publishing to CC
    As for this workflow, I get a little confused when you say:
    "allow me to switch iparts from the factory within the assembly it is inserted into."
    If you've published an iPart factory to CC, then you would use the CC tools to work with that family of parts in an assembly. You would sort of forget about the iPart factory after that. You're really only creating (and keeping it around afterwards) as a template to use for publishing. Once you've published the iPart to CC, there is not a connection between the iPart factory file and the CC files. You could actually delete the iPart factory if you wanted. But it's probably wise to keep it around in case you ever need to republish, etc.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Distinguished Contributor
    Lance_White
    06-08-2012 12:30 PM in reply to: Curtis_Waguespack
    Curtis,
     It doesn't work that way for pipe fittings, for some reason. It does work for everything else I tried.
    Lance W.
    Inventor Pro 2013 (PDS Ultimate)
    Vault Pro 2013
    Windows 7 64
    Xeon 2.4 Ghz 12GB
    Curtis_Waguespack
    06-08-2012 12:47 PM in reply to: Lance_White
    Hi white127,
    Ahh, you're quite right. As soon as I read fitting just now, it occurred that I remember skimming across something about fittings earlier in this thread. And now I see that you pointed this out right from the start.
    Soooo, it does work as I described for CC parts other than fittings and < insert other oddball CC parts that I'm not aware of  here >. :smileywink:
    Sorry for the confusion. :smileyembarrassed:
    I hope this helps.
    Curtis
    Cadmanto
    06-08-2012 12:56 PM in reply to: Curtis_Waguespack
    Well, that explains why I couldn't get it to work.
    So that changes my question slightly.  Why don't fittings work this way like the other CC parts?
    Best Regards,
    Scott McFadden
    Lance_White
    06-08-2012 12:58 PM in reply to: Cadmanto
    Aliens?
    Lance W.
    Vault Pro 2013
    Windows 7 64
    Xeon 2.4 Ghz 12GB
    JimSteinmeyer
    06-08-2012 02:28 PM in reply to: Lance_White
    The SW staff is sabatoging it.  :smileylol:
    Jim
    Inventor Premium 2013 SP1.1
    Vault 2013- plain vanilla version
    HP G71 notebook
    celeron cpu w\ 4gb RAM and 64 bit system
    Win 7 home premium
    Ya, my boss has me running my personal machine at work.
    06-08-2012 02:52 PM in reply to: Cadmanto
    I found this comment in another thread that may shed some light on why the pipe content behaves differently than other CC parts:
    dave.anderson wrote:
    Tube and Pipe content will behave differently that other placed components. Even ones that you insert using Place from Content Center will show in the browser with a Pipe Icon and not a Part one.
    This is due to the Tube and Pipe add-in. What you can do is disable the Add-in prior to inserting any T&P parts. This forces them to behave as "normal" parts and they can be restructured. I would not suggest this if they are part of a Pipe run, but for simply placed content it's fine.
    Dave Anderson
    MFG Support - Inventor
    The original thread is here:
    http://forums.autodesk.com/t5/Autodesk-Inventor/Demoting-moving-patterns-into-a-subassembly/m-p/3490...
    Curtis_Waguespack
    06-08-2012 02:54 PM in reply to: JimSteinmeyer
    Hi everyone,
    It turns out that it is the Tube and Pipe Addin that makes the fittings behave differently. If you have Inventor Professional but don't use the TP tools, or if you use it sometimes, but not others, then it might be worth unloading the TP addin. It's not recommended to do this when working with assemblies that use routes created with the TP tools of course, because you'll likely break some of the TP magic that resides with in them.
    To unload the add in, go to the Tools tab  and click the Add-ins button. In the Add-In Manager dialog box, locate the Routed Systems: Tube and Pipe addin and select it. Uncheck the Loaded/Unloaded checkbox to unload it. Note that if it's greyed out Inventor is using it (possibly just Content Center having the TP libraries loaded), and you might need to uncheck the Load on Startup checkbox and then restart Inventor.
    So once I unloaded the TP addin, the fitting iPart that was always behaving as a fitting, now behaved like a regular iPart factory.
    Give it a try and let me know if you don't see the same result, and I'll have another look.
    p.s. Thanks to Dave Anderson of AD for the suggestion.
    I hope this helps.
    Curtis
    Edit: I was too slow  cwhetten beat me to it! :smileyhappy:
    Cadmanto
    06-08-2012 07:49 PM in reply to: Lance_White
    From Desault Systems????
    Did I really just say that?  Oh my gosh am I converting?????  :smileysurprised:   :smileylol:
    Best Regards,
    Scott McFadden
