Optionally you can download an addin (C3_Overlay) that enables you to
overlay positional rep drawing views without creating an additional
assembly. Depending on your requirements, either program might be the best
solution. The lastest version of the add-in is available at
http://www.mcadforums.com/forums/viewtopic.php?t=1085
Neil
"Peter Maxfield (Autodesk)" wrote in
message news:415c526e$1_3@newsprd01...
> Hello Peter,
> Each base view in a drawing can call upon a given Positional Rep.
> You can place multiple views on the same sheet, each showing different
> PRs, such as the hydraulic ram in your example.
> If you would like them overlapping on top of each other, we have provided
> a VB application to generate a wrapper assembly with each PR as separate
> instances, each set to Reference. Creating a drawing view of this assembly
> will show your primary "master" design with the PRs you choose in
reference
> style.
> The application is called "OverlayAssembly" in the samples directory.
> Regards,
> Peter Maxfield
> Product Design
> Autodesk
> "Peter" wrote in message news:415b6da7_1@newsprd01...
> If a sub-assembly has positional representations, how do you create a
> drawing of the top-level assembly showing the various positional
> representations contained within the sub-assembly?
> E.g. A hydraulic ram is made from a piston and a cylinder (and some other
> bits, but this is keeping it simple) The piston and cylinder are
constrained
> such that a Mate constraint drives the ram open and closed. Two
Positional
> representations are created showing it fully open and fully closed. The
> strut assembly is now inserted into a general assembly where it forms part
> of a door mechanism.
> From the top level door assembly, how do you create a drawing of the two
> different positional representations of the strut? As far as I can see, a
> drawings can only be created from the top-level assemblies positional
> representations.
> I have tried creating top-level design views of the two sub-ass'y
positional
> representations: No joy. Am I missing something fundamental and/or
making
> the whole thing too complicated? I know I could promote the ram assembly
> into the top level assembly and make the positional rep's there, but that
> causes a whole lot more problems downstream.
> Hope the question makes sense.
> Peter
