• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Stemdriller
    Creating Dimensions on sketch
    141 Views, 3 Replies
    12-17-2012 08:11 AM
    Hi all
    One of our senior designers seems to think there is a setting when creating a sketch that will automatically dimension.
    So if a straight line is draw and 5 mm length is entered a 5 mm line will immedialtey be created, he seems to think that you can then immedialtey Dimension said line??
    I can't find anything, settings wise, but he is a switched on guy so just wondered if there is any truth to his claim?
    Gareth
    Please use plain text.
    Re: Creating Dimensions on sketch
    12-17-2012 08:36 AM in reply to: Stemdriller
    What version of Inventor are you using?
    For the past few releases you can enter the dimensions directly as you are creating the sketch.
    Inventor Professional 2014 Edu 64-bit
    Distinguished Mentor
    12-17-2012 09:00 AM in reply to: Stemdriller
    As JD said.
    App options, Sketch, Heads-Up Display, Create Dim's
    Valued Contributor
    Stemdriller
    12-18-2012 12:16 AM in reply to: rdyson
    Thank you to both for your responses.
    That is just what we was looking for.
    Thanks again
    GW
