• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Create flat pattern idws from an assembly
    361 Views, 1 Replies
    03-15-2012 08:08 AM
    To increase the speed of production, I like to generate idws of flat patterns from assembly. The following iLogic rule work fine inside a metal sheet (I had to create flat pattern before run this rule).
    Imports Inventor.ViewOrientationTypeEnum
    Imports Inventor.DrawingViewStyleEnum
    Dim oDrawingDoc As DrawingDocument
    Dim oPartDoc As Document
    Dim oSheet As sheet
    Dim oTG As TransientGeometry
    Dim oView1 As DrawingView
    Dim oOptions As NameValueMap
    	oPartDoc = ThisApplication.ActiveDocument
    	oDrawingDoc = ThisApplication.documents.Add(kDrawingDocumentObject, "C:\Users\Public\Documents\Autodesk\Inventor 2011\Templates\Standard.IDW", True)
    	oSheet = oDrawingDoc.Sheets.Item(1)
    	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    	oOptions.Add("SheetMetalFoldedModel", False)
    	oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(15#, 15#)
    	oView1 = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint1, 1/5#, kDefaultViewOrientation, kHiddenLineDrawingViewStyle, , , oOptions)
     But from an assembly there are some problem ( firstable I'm not an expert of vba and ilogic)
    fmgr = ThisApplication.Filemanager
    For Each file In fmgr.files
    doc = ThisApplication.Documents.ItemByName (file.fullfileName)
    compdef = doc.ComponentDefinition
    ' For each assembly or subassembly
    'If (doc.documenttype = 12291) Then
     For Each occ In compdef.Occurrences
    ' For sheet metal or part
        If (occ.definition.type =83886592) Then
    '	If (occ.definition.Subtype ="{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then
    		Dim oSheet As sheet
    '		MessageBox.Show("test1")
    '		Else
    '		MessageBox.Show("test2")
        End If
     Next occ
    'End If
    Next file
     Can someone help me?
    Please use plain text.
    Valued Mentor
    jcneal
    Re: Create flat pattern idws from an assembly
    03-15-2012 08:51 AM in reply to: MatteoC
    i guess you have to open sheet metal part before create its drawing document.
