Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Create dimension angle in dwg drawing
- Highlight
- Email to a Friend
i want to ask how to make the size for the angle in the distance between holes. i use the autodesk inventor 2013, please help step by step. i attach an example like this.
How to create dimension angle in dwg drawing
- Highlight
- Email to a Friend
I want to ask how to make the size for the angle in the distance between holes. I use the autodesk inventor 2013, please help step by step. I attach an example like this.
Re: How to create dimension angle in dwg drawing
- Highlight
- Email to a Friend
I am not i understand you correctly or not.
If you want to show the dimension overthere, i think the available options is u can use constuction lines.
If you need to create the holes as per the dimension? go to sketch and use circular pattern.
Inventor Professional Suite 2010
Windows 7
- Highlight
- Email to a Friend
I've made a 3D part, but I want to make a 2D drawing. When creating 2D I want to add a label that the distance between the hole using the angle to mm or inchi.how i can create this?
- Highlight
- Email to a Friend
- Create Center points for the circles by using sketch option.
- Exit sketch
- Then select the dimension tool pick the three center points defined first
see attached for more clear ....
Hopes this will help u ....
Accept as solution, If u foud so....
Windows 7
Re: Create dimension angle in dwg drawing
- Highlight
- Email to a Friend
How much Inventor training and/or experience do you have? Can you post a screen shot of the dimension as it looks now? I don't know what part of the dimension appearance is causing you a problem, so no idea how to advise you.
- Highlight
- Email to a Friend
well, it's even easier than that: no need to create a sketch and center points. you can snap to the centers of the holes directly. by the way ; this works in model sketches also.
cheers
rob
- Highlight
- Email to a Friend
Are you asking how to create this as a 'sketch'? If so, you'll need to utilize construction lines to dimension the angle.
ITO - Application Management
Factory Design Suite Ultimate 2012
AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
I've tried but could not. I attach the 3D part and DWG. and drawing what I want, maybe you can help me ...
