• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Accepted Solution
    Create dimension angle in dwg drawing
    756 Views, 15 Replies
    10-31-2012 06:47 PM
    i want to ask how to make the size for the angle in the distance between holes. i use the autodesk inventor 2013, please help step by step. i attach an example like this.
    Please use plain text.
    Active Member
    How to create dimension angle in dwg drawing
    10-31-2012 08:35 PM in reply to: 2shaen
    I want to ask how to make the size for the angle in the distance between holes. I use the autodesk inventor 2013, please help step by step. I attach an example like this.
    Valued Contributor
    jyothissurendran
    Re: How to create dimension angle in dwg drawing
    10-31-2012 10:12 PM in reply to: 2shaen
    I am not i understand you correctly or not.
    If you want to show the dimension overthere, i think the available options is u can use constuction lines.
    If you need to create the  holes as per the dimension? go to sketch and use circular pattern.
    Jyothis Surendran
    Inventor Professional Suite 2010
    Windows 7
    Active Member
    11-01-2012 12:43 AM in reply to: jyothissurendran
    I've made a 3D part, but I want to make a 2D drawing. When creating 2D I want to add a label that the distance between the hole using the angle to mm or inchi.how i can create this?
    Valued Contributor
    jyothissurendran
    11-01-2012 02:19 AM in reply to: 2shaen
    • Create  Center points for the circles by using sketch option.
    •  Exit sketch
    •  Then select the dimension tool pick the three center points defined first
    see attached for more clear ....
    Hopes this will help u ....
    Accept as solution, If u foud so....
    Jyothis Surendran
    Windows 7
    *Pro
    sbixler
    Re: Create dimension angle in dwg drawing
    11-01-2012 04:22 AM in reply to: 2shaen
    How much Inventor training and/or experience do you have?  Can you post a screen shot of the dimension as it looks now?  I don't know what part of the dimension appearance is causing you a problem, so no idea how to advise you.
    Member
    11-01-2012 05:09 AM in reply to: jyothissurendran
    well, it's even easier than that: no need to create a sketch and center points. you can snap to the centers of the holes directly. by the way ; this works in model sketches also.
    cheers
    rob
    Valued Mentor
    jclaidler
    11-01-2012 05:44 AM in reply to: 2shaen
    Are you asking how to create this as a 'sketch'?  If so, you'll need to utilize construction lines to dimension the angle.
    _______________________________________________________________
    ITO - Application Management
    Factory Design Suite Ultimate 2012
    AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
    Distinguished Mentor
    ampster
    11-01-2012 06:44 AM in reply to: 2shaen
    Active Member
    11-01-2012 07:30 PM in reply to: jyothissurendran
    I've tried but could not. I attach the 3D part and DWG. and drawing what I want, maybe you can help me ...
