Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Create a roller chain
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am trying to create a roller chain as part of a cad drawing of a bicyle.
I created a link of the chain (pic attached) and I am following this video to repeat it as a rectangular pattern : http://www.youtube.com/watch?v=DiBGYdbBPHo
However the links are not following the path they're supposed to - sorry I can't attach that file right now.
Anything that I should do different from the video?
Anything that you can think to point out would be helpful. I have been using inventor for a little while but I've never used the adaptive stetches or the functions thing ot a rectangular pattern that is not in the shape of a rectangle.
Re: Create a roller chain
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
mbus0013 wrote:- sorry I can't attach that file right now.
I think it would be virtually impossible to see where yours is going wrong without your assembly.
For information on curve driven patterns you might see this document
http://home.pct.edu/~jmather/skillsusa%20universit
...then attach your assembly when you can.
Inventor Professional 2014 Edu 64-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
this is what is looks like so far
Is there any way to make the 2 parts of the chain rotate about the pin? It's acting like it's fixed while it's not.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
mbus0013 wrote:this is what is looks like so far
I am not familiar with editing image files in Inventor (but it doesn't look correct).
Attach your Inventor assembly here.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i tried attaching but i can't attach it as a zipped file and there are too many files used in the assembly to upload one by one
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i had already found that - however when i open it I don't see any chain - how do i edit it?
printscreen attached
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There should only be 3 files.
the path
one link
the assembly file.
If you can't attach here then send me the assembly - jmather_at_pct_dot_edu
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
why is a helpful reply gone?
I am trying to use the chain found here: http://www.cbliss.com/inventor/Parts.htm
What other values shoul I edit in the excel sheet, anyone knows?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You need to drag the end of part marked all the way down. Then the chain will be there.
Inventor 2013
GeForce GTX 580
Windows 7 64 Bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes it worked!
Thank you.
