• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Create a Circular Component Pattern, and maintain Orientation
    337 Views, 8 Replies
    10-04-2012 11:10 AM
    Hi All,
    I was wondering if anyone can help my create a circular pattern in an assembly that maintains the orientation of the part being patterned.
    This is for foundation plates. There are 3 plates. The plates are square, and have bolt holes in the corners of the plates. Since there are 3 plates and its going around a circle, the angle between the plates is 120 degrees.
    Now, Ive been trying this for some time now and what is happening is the firs plate is fine, but then the second and third plate are rotated around their center axis. I would like it to simply remain as inserted and constrained within the assembly.
    I have attached a picture to be more clear about what I want and what I'm currently getting.
    Maybe someone knows more about this and can possibly help me out with this.
    I would really appreciate this.
    Cheers,
    Vijai Christopher Sookrah
    Mechanical Engineer, EIT
    Aircraft Appliances & Equipment Ltd.
    Please use plain text.
    *Pro
    jletcher
    Re: Create a Circular Component Pattern, and maintain Orientation
    10-04-2012 11:24 AM in reply to: vsookrah
    Me personally would not pattern 3 parts..
    But to answer you issue there is no way to control the part from rotating with circular pattern.
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    10-04-2012 11:27 AM in reply to: jletcher
    The reason why I try to pattern 3 parts is because we are trying to streamline this with an iassembly.
    Ive already got the 4 plates case in properly.
    to be completely honest I was hoping this would work just so there was no need to manually add parts.
    I cant believe there is no option for this.
    Thanks though
    *Pro
    jletcher
    10-04-2012 11:31 AM in reply to: vsookrah
    Oh I agree there should be an option to do this but this is Inventor they do as they wish not as we need...
    James Letcher
    10-04-2012 12:16 PM in reply to: jletcher
    I dont really understand why Inventor has such little functionality in this area and many more.
    I found a work around which I thought would save the day but then I woke up and smelt the coffee.
    My idea was to make the components that were out of orientation independant and then re mate them accordingly with the geometry. This would have worked well because it would blend in well with my iassembly features, but for some reason these parts dont have any references when made independant. Not only do they have no axis, no planes or points; in assembly files you dont have the ability to create planes, points, or axis as freely as you do in part files.
    For Shame, Autodesk. For Shame.
    *Pro
    jletcher
    10-04-2012 12:26 PM in reply to: vsookrah
    LOL thats funny that would have been my thought but I knew that making them independant would just be a part.
    James Letcher
    *Pro
    10-04-2012 02:13 PM in reply to: vsookrah
    Use rectangular pattern instead.  Sketch a 240° arc and use that for Direction 1; expand the dialog box (>>) and you have choices for orientation (I'm not on an Inventor computer now, so I can't give you the details or a screen shot).
    10-05-2012 08:19 AM in reply to: sbixler
    I may be wrong, but I do not know if this will work in an Assembly file or will this only work in a Part file.
    Cheers,
    Mechanical Engineer
    *Expert Elite*
    10-05-2012 08:24 AM in reply to: vsookrah
    Create pattern of workpoints (or other geometry) in part with this technique and then in assembly constrain using the part pattern feature.
