• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    MelJM
    Accepted Solution
    Create Flat Pattern Command Missing
    589 Views, 3 Replies
    12-27-2011 03:32 PM
    I recently switched to Inventor 2012 from a previous version. I cannot find the create flat pattern command. Some of my coworkers were able to customize their RMB menu to have this command, but I am not even able to do that! (They don't have the command on the ribbon, either.)
    I attached a picture of my sheet metal ribbon... don't know if it's helpful or not.
    Please use plain text.
    *Expert Elite*
    Re: Create Flat Pattern Command Missing
    12-28-2011 03:34 AM in reply to: MelJM
    Attach that ipt file here.
    *Expert Elite*
    Curtis_Waguespack
    12-28-2011 07:45 AM in reply to: MelJM
    Hi MelJM,
    This might help:
    http://forums.autodesk.com/t5/Autodesk-Inventor/Sheet-Metal-Part-Has-No-Flat-Pattern-Button/m-p/3268...
    If so, kudos to jeanchile for sharing the solution.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Member
    MelJM
    12-28-2011 08:17 AM in reply to: JDMather
    All I did on that part was create a face and add a flange, to see if on such a simple part the flat panel command would "appear".
    Just started up Inventor for the day, and the command was there. I have no idea what changed between yesterday and today. Stay tuned, perhaps it will dissappear again?
