• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Could not activate Rip Command
    130 Views, 3 Replies
    01-17-2013 04:58 PM
    After deleting some rips and corner seams on my model, I can no longer create rips, unfolds, or refolds.  They all come up with the same message as shown in attached picture.  Any ideas?
    I have already shut down and restarted.
    Rob
    Please use plain text.
    *Pro
    Re: Could not activate Rip Command
    01-17-2013 06:37 PM in reply to: RobJV
    Sounds as if a face got removed so you now have only a surface model.  But I do remember getting a message like this in the last few weeks, with a file someone posted on this forum, where the body was reported as a solid in the browser, but still gave this message when trying to apply a rip.  Seems as if it was somehow corrupted.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    *Expert Elite*
    01-18-2013 05:31 AM in reply to: sbixler
    How did you delete these features? Did you use the Delete Face command?
    01-18-2013 09:14 AM in reply to: JDMather
    Hi JD,
    No delete face command used.
    It is definitely a solid with volume and mass.  It contains a derived part but do not think that has anything to do with it. Interesting that somebody else had a similar issue.  I have even tried deleting everything all the way up to the derived part and recreating the extrusion, shell, and then ripping but same error.
    -Must be corrupted somehow.
    I will probably have to create a new part from scratch.
    Rob
