• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Copying Section Views
    119 Views, 2 Replies
    11-30-2012 05:19 AM
    I need to copy only the section views to other sheets & I couldn't find how to do this. Can anyone suggest the procedure?
    Sudhi
    Please use plain text.
    Re: Copying Section Views
    11-30-2012 05:30 AM in reply to: SUDHI.KN
    Do you want to copy or simply move?
    To move click and drag the section node in the browser to the second sheet.
    To copy first create a duplicate section in first sheet and then click and drag as above instruction.
    When you do this click and drag you will see a black bar in the browser for the second sheet when done correctly.
    Inventor Professional 2014 Edu 64-bit
    Member
    11-30-2012 05:57 AM in reply to: JDMather
    Mather,
    Thank you! It works.
