• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    mrattray
    Re: Copy paste sketch in idw files
    09-12-2012 10:14 AM in reply to: Josy05
    If it's a sketch inside of an idw, then we don't need the other files to see that. Try just the idw alone as Sam suggested.
    Mike (not Matt) Rattray
    Please use plain text.
    Josy05
    09-12-2012 10:43 AM in reply to: sbixler
    My file is pretty big, even when zipping only the idw it's twice the limit for this site.
    My sketch includes the circle but I don't think that this is causing the problem.
    *Pro
    jletcher
    09-12-2012 10:47 AM in reply to: Josy05
    Ok so in this IDW you have alot of things ?
    If so try this take just the sheet you have the sketch on in the browser copy the sheet start a new IDW (leaving this one open) in the browser white area right click and paste and see if you can now post..
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    Josy05
    09-12-2012 11:08 AM in reply to: jletcher
    I see that it's the sketch that is big, not the rest of the information on the idw. Because of that I'm unable to send you the file. It seem it does not like my copy from CAD, probably too much info carried from one program to the other.
    *Pro
    jletcher
    09-12-2012 11:54 AM in reply to: Josy05
    When you copy from cad it gives you a load of junk. I would suggest not doing that if you can.
    Well I am sorry we cold not help :smileysad: Autodesk may jump in and set up a ftp you can send to them..
    James Letcher
