Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Copied by Design Assistant assembly cannot be altered in Design Assistant
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello
I just made a copy of assembly in Design Assistant.
I opened the copied assembly in Design Assistant to make some changes.
Parts are accessible but I have only "Clear" option possibe.
Please advice the possible reasons why?
http://screencast.com/t/VYsx600WSzQ
Orest Yavtushenko
Re: Copied by Design Assistant assembly cannot be altered in Design Assistant
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It is likely that your _ASSEMBLY folder is a Library.
Check your Project settings, and if you have to make changes to a Library, use a suitable project (the one specially set up to enable changes to Library parts, with CAUTION).
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The assembly file does not belong to custom library.
If it even does I could not copy it from the beginning. As you can see I do copy of assembly and than open this copy which has accessible but not editable parts. The Standard Parts (library parts) are not accessible at all (grey).
Orest
