• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Bender, Keith
    Coordinate system - sketch - cannot move
    55 Views, 2 Replies
    11-18-2002 10:43 AM
    Hi all,
    I've been struggling with this problem for some time now, so thought I'd ask
    if anyone knows the solution. Sometimes, I move the sketch coordinate
    system with no problem at all. Other times, I can NOT make it move no way.
    For example, I just began a new assembly, creating parts in place, and on
    the first grounded part, I moved the sketch coordinate system on several
    sketches without problems. I moved it so I could predictably insert AutoCAD
    .DWG into the sketch, and it worked beautifully. I've done this many times
    before, so I know it can work. I then created several more parts, with
    geometry projected from the first part. I then began a fourth part,
    projected some geometry, and tried to move the sketch coordinate system.
    Now, what I just did awhile ago WILL NOT WORK. I've tried everything -
    closed Inventor, re-booted, started a simple .IPT , etc... I can select the
    coordinate system Origin, and the next prompt ask me to "Select a Vertex,
    Circular Edge, Workpoint, or Sketchpoint", but NOTHING seems to be
    selectable.
    Please, has anyone else seen this? What am I missing?
    Keith
    Please use plain text.
    *Keller, Kent
    Re: Coordinate system - sketch - cannot move
    11-18-2002 11:27 AM in reply to: *Bender, Keith
    Keith
    I am pretty sure there must be a feature for it to work...... for instance I
    don't think you can change it in the first sketch.
    Anyhow if you have a simple ipt go ahead and post it to customer files.
    Kent Keller
    Member of the Autodesk Discussion Forum Moderator Program
    http://www.MyMcad.com/KWiK/Mcad.htm
    "Keith Bender" wrote in message
    news:045233FF1154F1B9C118C90D34363B87@in.WebX.maYIadrTaRb...
    *Germer, Ole
    Re:
    11-18-2002 08:07 PM in reply to: *Bender, Keith
    Have you though about moving the autocad sketch after inserting it. That is
    the easiest way to deal with it. That is what I do. I never bother moving
    the coordinate system. Too aggravating.
    Ole Germer
    Helping create better involute profiles for gears
    http://www.geocities.com/olegermer/index.html
    "Kent Keller" wrote in message
    news:C765A8002C69139131F53FB9F64785B5@in.WebX.maYIadrTaRb...
    > Keith
    I
    > Kent Keller
