Autodesk Inventor
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Bender, Keith
Coordinate system - sketch - cannot move
Options
- Highlight
- Email to a Friend
56 Views, 2 Replies
11-18-2002 10:43 AM
Hi all,
I've been struggling with this problem for some time now, so thought I'd ask
if anyone knows the solution. Sometimes, I move the sketch coordinate
system with no problem at all. Other times, I can NOT make it move no way.
For example, I just began a new assembly, creating parts in place, and on
the first grounded part, I moved the sketch coordinate system on several
sketches without problems. I moved it so I could predictably insert AutoCAD
.DWG into the sketch, and it worked beautifully. I've done this many times
before, so I know it can work. I then created several more parts, with
geometry projected from the first part. I then began a fourth part,
projected some geometry, and tried to move the sketch coordinate system.
Now, what I just did awhile ago WILL NOT WORK. I've tried everything -
closed Inventor, re-booted, started a simple .IPT , etc... I can select the
coordinate system Origin, and the next prompt ask me to "Select a Vertex,
Circular Edge, Workpoint, or Sketchpoint", but NOTHING seems to be
selectable.
Please, has anyone else seen this? What am I missing?
Keith
selectable.
Keith
*Keller, Kent
Re: Coordinate system - sketch - cannot move
Options
- Highlight
- Email to a Friend
11-18-2002 11:27 AM in reply to:
*Bender, Keith
Keith
I am pretty sure there must be a feature for it to work...... for instance I
don't think you can change it in the first sketch.
Anyhow if you have a simple ipt go ahead and post it to customer files.
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"Keith Bender" wrote in message
news:045233FF1154F1B9C118C90D34363B87@in.WebX.maYI adrTaRb...
Kent Keller
"Keith Bender"
*Germer, Ole
Re:
Options
- Highlight
- Email to a Friend
11-18-2002 08:07 PM in reply to:
*Bender, Keith
Have you though about moving the autocad sketch after inserting it. That is
the easiest way to deal with it. That is what I do. I never bother moving
the coordinate system. Too aggravating.
Ole Germer
Helping create better involute profiles for gears
http://www.geocities.com/olegermer/index.html
"Kent Keller" wrote in message
news:C765A8002C69139131F53FB9F64785B5@in.WebX.maYI adrTaRb...
> Keith
I
> Kent Keller
Ole Germer
"Kent Keller"
> Keith
I
> Kent Keller
> "Keith Bender"
