• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Converting a surface into a solid body
    858 Views, 7 Replies
    09-28-2012 03:14 PM
    I am trying to convert this composite surface into a single solid body, however when I try to stich the surfaces in the construction environment it always crashes. I have also tried edditing the STEP file import options but it still always opens as a composite surface.
    Eric
    Please use plain text.
    Re: Converting a surface into a solid body
    09-28-2012 03:17 PM in reply to: collinseric
    No file attached?
    Member
    09-28-2012 03:20 PM in reply to: JDMather
    I'm having touble uploading it... says the file size is too large... already compressd it in a zip. Solutions?
    09-28-2012 03:24 PM in reply to: collinseric
    Depends on where you have it.
    In Inventor?
    Drag the Red End of Part marker above the Composite body and nothing in Construction (or Repair) environment.
    Save the file in a rolled up state and then zip.
    If still larger than 1.5 meg the limit is 10Meg over here http://www.augi.com
    Member
    09-28-2012 03:48 PM in reply to: JDMather
    09-28-2012 03:58 PM in reply to: collinseric
    The most obvious question - Why would you even need that as solids?  Wouldn't you simply purchase from the company?
    Distinguished Contributor wh
    wh
    Betreff: Converting a surface into a solid body
    09-29-2012 02:40 AM in reply to: collinseric
    This seems to be a derived part from a SWX 2010 assembly, as can be seen in the translation report.
    I've seen several similar parts, and most of them had lots of missing or distorted faces. SWX derived parts seem to be only minor quality.
    With lots of spare time and some knowledge, you can rebuild these imports. But that's no fun.
    Walter
    09-29-2012 04:03 AM in reply to: JDMather
    If you need to include in assembly drawing - simply tell Inventor to include surfaces.
    If you want it to "appear" solid - right click and turn off Translucent.
    If you reall want to take the time to convert to solids you will need to create Groups in Repair (Construction) environment and isolate the different parts into different groups.  Patch the missing surfaces, stitch and promote. (an all day job on this assembly)
