Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Convert to sheet metal doesn't make all bends
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Godmorning.
Iam having trouble with a part that I wont to convert to sheetmetal and make a drawing with bend annotations.
Converting the part goes fine but the flat pattern is only a "semi-flat-pattern" 2 of the 4 bends doesn't unfold.
I have a 8mm plate and the internal radius is 2mm and the external radius is 10mm and the bend angel is 10 degrees sow everything should be fine.
But how to add the last to bends to make my flat pattern unfold correctly?
Jens
Inventor Professional 2012
Vault Professional 2012
Re: Convert to sheet metal doesn't make all bends
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Check your first sketch. The distance between the two 10 degree bends is not exactly 8mm and that is why it won't flatten.
Inventor Product Design Suite Premium 2013 SP1.1
Windows 7 Professional - 64 bit
HP h8-1380t - i7-3820 @ 3.6 GHz
10 Gb
AMD Radeon HD7950 3Gb
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Maybe something like this (see attached).
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the help.
Looking at your part makes me think it is funny how different ways of working in inventor can be.
Do you allways make the complete 2d layout and then add material afterwards?
Normally I would go directly to 3d and then manipulating (adding/removing) material but seems like that in sheet metal the sketched up part works better for this purpose.
Jens
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
jsr wrote:
Do you allways ....
I try to always avoid work - do it the easy way. Sometimes I am more succesful at avoiding work than other times.
