• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Contributor jsr
    jsr
    Accepted Solution
    Convert to sheet metal doesn't make all bends
    423 Views, 4 Replies
    04-02-2012 11:07 PM
    Godmorning.
    Iam having trouble with a part that I wont to convert to sheetmetal and make a drawing with bend annotations.
    Converting the part goes fine but the flat pattern is only a "semi-flat-pattern" 2 of the 4 bends doesn't unfold.
    I have a 8mm plate and the internal radius is 2mm and the external radius is 10mm and the bend angel is 10 degrees sow everything should be fine.
    But how to add the last to bends to make my flat pattern unfold correctly?
    Kind Regards
    Jens
    Inventor Professional 2012
    Vault Professional 2012
    Please use plain text.
    Active Contributor
    Re: Convert to sheet metal doesn't make all bends
    04-03-2012 05:26 AM in reply to: jsr
    Check your first sketch. The distance between the two 10 degree bends is not exactly 8mm and that is why it won't flatten.
    Donald L.
    Inventor Product Design Suite Premium 2013 SP1.1
    Windows 7 Professional - 64 bit
    HP h8-1380t - i7-3820 @ 3.6 GHz
    10 Gb
    AMD Radeon HD7950 3Gb
    *Expert Elite*
    04-03-2012 09:34 AM in reply to: jsr
    Maybe something like this (see attached).
    Contributor jsr
    jsr
    04-03-2012 10:36 PM in reply to: JDMather
    Thanks for the help.
    Looking at your part makes me think it is funny how different ways of working in inventor can be.
    Do you allways make the complete 2d layout and then add material afterwards?
    Normally I would go directly to 3d and then manipulating (adding/removing) material but seems like that in sheet metal the sketched up part works better for this purpose.
    Kind Regards
    Jens
    *Expert Elite*
    04-04-2012 04:57 AM in reply to: jsr
    jsr wrote:
    Do you allways ....
    I try to always avoid work - do it the easy way.  Sometimes I am more succesful at avoiding work than other times.
