• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    zdhrichard
    Convert STEP model to IPT Issue
    235 Views, 3 Replies
    11-19-2012 07:40 AM
    I knew this is not a new problem, and I do search some people's solution. Even I followed up their way as
    http://forums.autodesk.com/t5/Autodesk-Inventor/Surface-Models-Convert-to-Solids/m-p/3452492/highlig...)
    , but still I cannot get correct solid model when I try to convert attached STEP model to IPT. I just can get surface model, but I do not solid one.
    Could somebody help me to convert it to solid model (ipt)?
    Your help will be much appreciated.
    Richard Z.
    Autodesk Inventor Professional 2013 (64 Bit) SP1.1
    Windows 7 Professional Service Pack 1
    Intel(R) Xeon(R) CPU E5645
    12.0 GB Memory
    Please use plain text.
    *Expert Elite*
    Re: Convert STEP model to IPT Issue
    11-19-2012 08:07 AM in reply to: zdhrichard
    There are many surfaces missing.
    As this is simple geomtry - it might be fastest to simply redraw it using the original only for reference.
    Why would you need it as a solid body - isn't this an off-the-shelf purchased item?
    Valued Mentor
    stephengibson76
    11-19-2012 08:13 AM in reply to: zdhrichard
    looks like a lot of your holes thru the part need to be patched, you can either patch the surface hole and lose them in the solid, or you can draw a surface cylinder wetween each face where the holes occur...
    Turning composite non transluccent might help you spot these problems
    Stephen Gibson
    Autodesk Product Design Suit 2012
    Win 7 Enterprise 64bit
    Intel core i7 2600K Clocked @ 4.7GHz
    16Gb Ram
    Nvidia GTX 580
    Valued Contributor
    zdhrichard
    11-19-2012 09:02 AM in reply to: zdhrichard
    Thanks lot for your suggestion.
    Unfortunately, this 3D model is provided by vendor.
    Looks like I have to use surface model.
    Richard Z.
    12.0 GB Memory
