• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Controlling the motion
    404 Views, 10 Replies
    11-02-2012 07:27 AM
    Hey,
    i'm doing the assembly to the part that i attatched, but i have problem when i'm "rotating it", as the parts break their axis, the crankrod moves into the oppisite direction, and also the reverse gear. But i dont know how to limit their motion. also the steam chest slide valve rod is out of control.
    Here is it, http://www.youtube.com/watch?v=-X7LswXveW8&feature=related
    So how do i limit their motion?... via.. angle or between two locations/measurement..?
    ps. I use inventor 2012
    Please use plain text.
    *Expert Elite*
    Re: Controlling the motion
    11-02-2012 09:19 AM in reply to: rickardwahlstrom
    An assembly file (*.iam) is simply a list of hyperlinks to the part files and a record of constraints.
    You must inlcude the part (*.ipt) files.  This should have been covered in your class.
    11-02-2012 09:35 AM in reply to: JDMather
    I understand, So should i send everyone? Or how do i include them in the "iam?
    *Expert Elite*
    11-02-2012 09:42 AM in reply to: rickardwahlstrom
    Place in folder.  (might have to use several)
    Right click on folder and select Send to Compressed (zipped) Folder.
    Attach the resulting *.zip file here (cannot be larger than 1.5 Meg, thus the reason it might take more than one folder).
    11-02-2012 09:52 AM in reply to: JDMather
    Well, i made the folder to an *zip* format, but it was 15 meg big .. maby couse it's around 40 parts in it
    11-02-2012 10:09 AM in reply to: JDMather
    Here i made photo of it, becouse u maby dont need the parts to help me.
    you can see where it goes to ****t in the pictures, and i want to limit their motion so they cant "jump" away like that, (when i rotate). "just lock them from going beyond a certain position/angle . The video can be to much help.
    11-02-2012 10:52 AM in reply to: JDMather
    11-02-2012 10:53 AM in reply to: JDMather
    JanVarholik
    11-07-2012 05:45 AM in reply to: rickardwahlstrom
    BTW: Take a look at "Pack and Go" which is available in Inventor (if you did not use it before). http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0684-Collabor684/0710-Design_A71...
