• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    thedelee
    Contour Roll with split will not unfold
    59 Views, 0 Replies
    06-23-2011 07:18 AM
    I am having a problem with the contour roll feature. I am adding 3/8" ti a length of straight duct to make an egde. it works ok except that when I split the thing to length ( joins into a y connector). It will no longer unfold. also looking for the setting to get the flat patterns to match true length (see the unsuppress to unfold, while suppressing the first two features for the true length). On the contour roll suppressing the split will allow it to unfold. unfortunately that is useless to us.:manmad:
    Thaddieus Fransman
    Please use plain text.
