Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Content center parts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is anyone facing the same problem that Inventor CC parts don't show in Showcase?
Re: Content center parts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello
Can you tell me what version of Showcase and Inventor you are using.
Also
Would you be able to attach the Inventor CC Part so that I can check it out.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I assume you have no the cc part in your project location or you just copy all the inventor files, not include the cc file to another location.
I would suggest you use Pack and Go to include all the files you needed, then import into Showcase, you will get what you want.
__________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
AutodeskCare | Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, Emily is correct
Showcase does import CC parts, but you have to make sure that the link to the ipt files is there.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the tip about pack and go. ![]()
I'm using the 2013 suite and in inventor you can use the " suite workflow" command, from there I choose " showcase constrained animation" Because my goal is to have a nicely rendered animation.
Do I have to conclude that this is not the correct method? If possible I prefer this workflow because it allows me to easy do changes in Inventor and update the model in showcase. With the pack and go method this would be more cumbersome I assume
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Suites Workflow is new feature for FDS 2013 and used to transfer files between different applications smoothly and efficiently, your operation is correct and recommended.
I can reproduce your issue on my machine, but I didn't find the reason till now, so I need some time to work with my team on your problem and will update to you when I got more info.
Emily Xu
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just got two suggests for your issue.
1 Place the cc parts As Custom and save them under the path of Project folder.
2 If you want to use cc parts As Standard.It's better setting the folder options for content center file under the path of your Project location,not use the default location.
These solutions will let showcase find the content center files.
Please let me know if you have any question.
Emily Xu
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you very much to report this issue! We are working with Autodesk Development team on this problem, and will update to you as I got more info.
Emily Xu
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi.
i've the same problem.
Are there news about?
Thank you.
