• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Active Member
    cs2106
    Accepted Solution
    Content Center
    138 Views, 9 Replies
    02-07-2012 11:54 AM
    All,  my content center has gone away and I don't know where to find it.  There is not even an option to make adjustments to the content center in the manage projects window.  All my paths seem correct and I'm not sure what else to check.  Any insight would be great.  Thanks.
    C Schaefer
    Distinguished Mentor
    Re: Content Center
    02-08-2012 05:00 AM in reply to: cs2106
    more info needed...
    what version of Inventor?
    Where was the CC located or used from previously, ie, Vault or Desktop Content?
    Valued Mentor
    Re: Content Center
    02-08-2012 08:31 AM in reply to: cs2106
    Odd...  A large swath of my users lost their content center yesterday.  For an unknown reason, their CC options were automatically changed from vault server to desktop content.
    This may be what happened to you.  If so, try going to Application Options > Content Center tab > change Access Options from Inventor Desktop Content to Vault Server.
    -cwhetten
    Please click "Accept as Solution" if this response answers your question.
    IV2012 Professional SP1, Build 190; Vanilla Vault 2012, Update 1
    Windows 7 Pro 64-bit SP1; Intel Xeon Duo @2.40 GHz, 6 GB RAM,
    NVIDIA Quadro 2000, 1024 MB GDDR5
    Active Member
    cs2106
    Re: Content Center
    02-08-2012 10:14 AM in reply to: ampster
    Using Ultimate 2012 version as a single user and the CC was on the desktop.
    C Schaefer
    Active Member
    cs2106
    Re: Content Center
    02-08-2012 10:19 AM in reply to: cwhetten
    cwhette,
    Interesting how so many lost the content center.  I was already a desktop content center user but I checked and all the settings were correct.  Also, under manage project there is no option for working with content centers.  Thanks
    C Schaefer
    Valued Mentor
    Re: Content Center
    02-08-2012 11:25 AM in reply to: cs2106
    Did your Windows user account get corrupted?
    Or, maybe check your Inventor add-ins.  Tools > Add-in Manager.  Check to make sure the Content Center add-in is loaded.
    -cwhetten
    cbenner
    Re: Content Center
    02-08-2012 11:37 AM in reply to: cwhetten
    Good call cwhetten...
    Did you have a crash recently?  I've noticed sometimes after a crash all add-ins will unload, giving you unexpected behavior.
    ChrisB
    "Alcohol never solved anyone's problems,... but then again niether did milk."
    Active Member
    cs2106
    Re: Content Center
    02-08-2012 01:00 PM in reply to: cwhetten
    cwhetten.
    .no crashes recently but good call on the add-in manager.  I checked it and everything in it had been turned off or reset with no good explination why.  Thanks a million!!
    C Schaefer
    Valued Mentor
    Re: Content Center
    02-08-2012 01:04 PM in reply to: cs2106
    Glad that worked.  The only time I have had issues with add-ins turning themselves off is from installing a service pack.  Other than that, I have no idea why an add-in would suddenly be disabled... :smileyfrustrated:
    -cwhetten
    cbenner
    Re: Content Center
    02-09-2012 04:49 AM in reply to: cwhetten
    I've been having this issue lately as I have been playing with the Job Processor... not very successfully either.  JP is either very slow or locks up altogether, forcing me to kill it in the Task Manager... which then fubars Inventor the next time I try to open it.  Inventor freezes at the splash, and when I finally get it open, all Add-Ins are unloaded.
    For now my fix is to stop playing with Job Processor.  For all the help it's been, I can create my dwf's the old fashioned way much faster.
    ChrisB
