• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    dpsmith85
    Content Center naming convention changed?
    54 Views, 0 Replies
    04-05-2012 11:13 AM
    I have a question regarding the content center naming convention for the "stock" category.  I have Inventor Professional 2010 and had it installed on an old XP machine.  I recently upgraded to a new windows 7 machine and did a fresh install of Inventor.  Since I did the install I am noticing that the content center is naming the "stock" category something different.  For example, when I used to create a steel L angle the stock number would read "Angle, 2 x 2 x 3/16" now it reads "L 2 x 2 x 3/16".  I've also noticed it with flat bar that Inventor labels it 4 x 3/8 when it used to be 3/8 x 4.
    I inherited that XP PC from an old employee and am now assuming that they had customized the content center on that computer to display what it used to.  If this is the case where do I go to set it back?
    Thanks for the help
    Please use plain text.
