• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Expert Elite*
    cbenner
    Re: Content Center measurements
    11-12-2012 08:33 AM in reply to: Cool_Breeze_Jr
    It sounds like you want to look into Vault 360.  I'm afraid that I have only very basic knowledge about setting up Vault, I've done one semi successful upgrade with IT help and A LOT of advice from people on these and other forums.  I would recommend a professional of some sort, though I know that will run into $$$.
    There are a lot of arguments in both directions for a small group.  I'd hate to push you into Vault and have you hate it in 6 months.... I guess tread lightly and do some research.
    This started off as a Content Center library issue and evolved from there.  I'm going to go back and reread your original post, to see if there is anything we can do to help you while you look into long term solutions.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Please use plain text.
    *Expert Elite*
    cbenner
    11-12-2012 09:02 AM in reply to: cbenner
    Try these steps to set up a library in your project file, it needs to be a read/write library.  Once you have a library of your own, you can copy CC items to it using a "save as".  Once it's in your library, you can modify the CC part however you need.
    ChrisB
    Valued Contributor
    Cool_Breeze_Jr
    11-12-2012 09:13 AM in reply to: cbenner
    Ok I will try this in a little while, thx...:smileyhappy:
    Chris Biggs
    Engineer/CADD Services
    New Horizons RV Corp.
    2401 Lacey Drive
    Junction City, KS 66441
    Dell XPS 8300
    Intel(R) Core(TM) i7-2600 CPU@3.40GHz
    16GB RAM
    Win 7 64
    Yeah, it kicks booty!
