• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    jyothissurendran
    Content Center Editing!!!`
    193 Views, 3 Replies
    09-24-2012 05:53 AM
    I have created a new item in content center in my personnel library. Regarding that i have a quick question.
    When i am creating a new item in content center its creating  *.ipt file somewhere ? If so from which location i can open the part file ?
    Please help....
    Jyothis Surendran
    Inventor Professional Suite 2010
    Windows 7
    Please use plain text.
    Cadmanto
    Re: Content Center Editing!!!`
    09-24-2012 06:02 AM in reply to: jyothissurendran
    When you publish the file to the CC it is not copying the .ipt persa.  It is creating the recipe
    needed to create and insert the part into an assembly.  I believe it is creating the HTML code when publishing.
    If you want to edit it or change it you are going to have to delete it out of the CC, change the one
    on your local then republish it back to CC.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    Valued Contributor
    jyothissurendran
    09-25-2012 09:44 PM in reply to: Cadmanto
    Thanks scott ...
    Jyothis Surendran
    Windows 7
    Cadmanto
    09-26-2012 05:21 AM in reply to: jyothissurendran
    You're welcome.  Glad it worked out for you.  :smileyhappy:
    Best Regards,
    Scott McFadden
