• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    New Member
    Constraints
    52 Views, 3 Replies
    11-14-2002 07:13 PM
    Can somebody help me how to constraint an 'O'rin into an 'O'ring groove. I've placed an "Mate" between the two axis but I can not stop the 'O'ring from moving along the rod.
    Thank you
    Nina
    Please use plain text.
    *Dotson, Sean
    Re: Constraints
    11-14-2002 10:06 PM in reply to: Kuma_Liska
    This really needs to be in one of the support NGs..
    but...
    You need to reference a workplane on the oring to
    another surface on the shaft.  Use one of the origin planes or make a new
    user plane on the oring.
    Sean Dotson, PE
    href="http://www.sdotson.com">http://www.sdotson.com
    ...sleep is for the
    weak..
    Thank you
    Nina
    *Chasek, Jerry
    Re: Constraints
    12-10-2002 01:04 AM in reply to: Kuma_Liska
    I have a hydraulic cylinder assembly, The Body and the ram are separate
    assemblies inserted into a larger assembly. One end is in place and
    constrained with an axis mate, such as a pin inserted. I go to mate the axes
    of the other end an I get an error. This is unfinished but I will try to
    post the assembly. I have never posted one so any advice would help as this
    is a large file.
    Jerry
    *Keller, Kent
    Re:
    12-10-2002 01:10 AM in reply to: Kuma_Liska
    I am not sure I understand what level the parts are on, but you may have to turn on
    adaptivity in one of the subs to get it to move. Can you drag it at all with the mouse?
    How large is large? open each part, and roll the eop marker to the top, and then zip it
    all up. Should make it smaller. Customer files max is 10 mb, but you aren't going to get
    to many people downloading something that big even.
    Kent
    Member of the Autodesk Discussion Forum Moderator Program
    "Jerry Chasek" wrote in message
    news:F7C1312ABEF921B882C3AF0CE34FE682@in.WebX.maYIadrTaRb...
    > is a large file.
    > Thanks
    > Jerry
