Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Constraint Virus?
- Highlight
- Email to a Friend
For 3 or 4 days now, 90% of the time I place a mate or flush constraint, it automatically offsets to some random direction and I have to reset to zero. Anyone know what might be causing this?
Re: Constraint Virus?
- Highlight
- Email to a Friend
I have never seen this behavior.
Is this with 2013?
Do you have Predict Offset enabled?
Can you attach an assembly here that exhibited this behavior (accept the offset constraint - don't reset it to zero). Only need the parts that are constrained.
Inventor Professional 2014 Edu 64-bit
- Highlight
- Email to a Friend
In the constraint dialogue box you have ticked the box with an image of a ruler next to it. When ticked if faces are parallel the dimension they are offset by is automatically placed in the offset box.
Regards
Martin
PDSU 2014 Update 1
Windows 7 64bit, Office 2007 Pro
Intel i7 980x, 24 Gb DDR3 RAM
Geforce 580GTX Graphics (Diver 310.70)
256GB SSD OS, 80GB SSD working folder
Space Pilot
- Highlight
- Email to a Friend
Hi! Could you show me an example by providing Inventor files or a video? What release of Inventor are you on?
Thanks!
Principal SQA Engineer, Inventor
Manufacturing Group
Autodesk, Inc.
- Highlight
- Email to a Friend
Ha. Yes, I must have clicked the "Predict Offsets" box. I didn't even know if was there. It's unchecked now and everything seems to be back to normal. Thanks again.
- Highlight
- Email to a Friend
Then it should have been 100% in your original problem description.
Watch out for this one as if your parts are already close to alignment you might not even notice the offset and this is one of the few setting changes that persist after leaving the dialog (I think even after leaving a session of Inventor - but I would have to check on that).
- Highlight
- Email to a Friend
I believe you are correct. In the future, I will be more cautious of this.
- Highlight
- Email to a Friend
It does persist across sessions (I normally have it turned on). It does only work when the mating faces are aligned though, if there is any rotation then the value remains zero.
Regards
Martin
PDSU 2014 Update 1
Space Pilot
