Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Constraint Dots
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have Inventor 2012. When I work on a new model, I have the Yellow and Green dots when sketching.
However if I work on an older model, the dots do not appear. I have everything on. See attachments. Not sure what else to check.
Re: Constraint Dots
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
On an existing sketch you will have to use show constraints to see the conincident constraints (yellow boxes).
Re: Constraint Dots
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: Constraint Dots
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Actually didn't mean the grips. I meant the yellow dot that follows the cursor and the green dot that shows up when your cursor is on an end point, midpoint or intersection point.
Re: Constraint Dots
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: Constraint Dots
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OP's first pic shows those already set.
Just a guess since you mentioned older files, is it possible these files have not been fully migrated or saved up to the latest version you are using?
Re: Constraint Dots
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Turns out it is my part that is causing the problem. After leaving Inventor and going back into it, things went back to normal. However the more I worked with the part, it became progressivly unstable. Not sure why part is doing that.
Re: Constraint Dots
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
if possible, post your file/s here for others to look over.
I don't have 2012 myself, still on 2011 but maybe someone else can take a peek into your model and prehaps find something odd in there.
Re: Constraint Dots
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Oops, missed that.
Re: Constraint Dots
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Have you done a rebuild on the part?
