• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Constraint Dots
    221 Views, 9 Replies
    09-13-2012 09:59 AM
    I have Inventor 2012.  When I work on a new model, I have the Yellow and Green dots when sketching.
    However if I work on an older model, the dots do not appear.  I have everything on. See attachments.  Not sure what else to check.
    Please use plain text.
    Distinguished Mentor
    Re: Constraint Dots
    09-13-2012 10:53 AM in reply to: cadcamm99
    On an existing sketch you will have to use show constraints to see the conincident constraints (yellow boxes).
    John Retzlaff
    *Expert Elite*
    cbenner
    Re: Constraint Dots
    09-13-2012 10:59 AM in reply to: john.retzlaff
    Quick key to show Constraints is F8, just for reference.... F9 turns them off.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Re: Constraint Dots
    09-13-2012 11:10 AM in reply to: cbenner
    Actually didn't mean the grips.  I meant the yellow dot that follows the cursor and the green dot that shows up when your cursor is on an end point, midpoint or intersection point.
    *Expert Elite*
    mrattray
    Re: Constraint Dots
    09-13-2012 12:26 PM in reply to: cadcamm99
    Mike (not Matt) Rattray
    ampster
    Re: Constraint Dots
    09-13-2012 12:30 PM in reply to: mrattray
    OP's first pic shows those already set.
    Just a guess since you mentioned older files, is it possible these files have not been fully migrated or saved up to the latest version you are using?
    Re: Constraint Dots
    09-13-2012 12:35 PM in reply to: cadcamm99
    Turns out it is my part that is causing the problem.  After leaving Inventor and going back into it, things went back to normal.  However the more I worked with the part, it became progressivly unstable.  Not sure why part is doing that.
    ampster
    Re: Constraint Dots
    09-13-2012 12:37 PM in reply to: cadcamm99
    if possible, post your file/s here for others to look over.
    I don't have 2012 myself, still on 2011 but maybe someone else can take a peek into your model and prehaps find something odd in there.
    *Expert Elite*
    mrattray
    Re: Constraint Dots
    09-13-2012 12:49 PM in reply to: ampster
    Oops, missed that.
    Re: Constraint Dots
    09-13-2012 01:00 PM in reply to: cadcamm99
    Have you done a rebuild on the part?
    John Retzlaff
