• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Russ
    In reflection....
    01-25-2007 08:00 AM in reply to: *Russ
    All the comments here are appreciated. I can see the mistake of starting an
    assembly and relying on just "grounding" the base part.
    This is a somewhat complex subject for the guy with just over a year in
    Inventor, but as time goes along much is learned.
    I would be very interested in looking at some assemblies to see how some of
    you with more experience do things in regard to constraints, browser use, so
    on. Its one thing to type up a tutorial but examples are very powerful to
    analyze and learn from.
    If you have something I can look at please email to cad@tannersacre.com
    Thanks to all (This is a very informative news group!)
    Russ Tanner
    wrote in message news:5462681@discussion.autodesk.com...
    http://www.sdotson.com/freetut/tipsforassemblies.pdf
    Please use plain text.
    *John-IV1.000E +001 SP0.3.000E +001
    Re: Constrain to origin?
    01-25-2007 11:39 AM in reply to: *Russ
    More likely your boss just didn't understand what is required to properly
    apply the tool and assumes it's just another type of AutoCAD, incorrectly,
    like most other managers. It is a common flaw of most organizations to
    oversimplify implementations of new technology in general and wind up
    learning the hard way, doing things more than once, and winding up going
    over budget and behind schedule.
    wrote in message news:5462969@discussion.autodesk.com...
    (When I started Inventor) if I would have read this and continuously tried
    to apply it along with working through the tutorials provided by J.D. Mather
    and sDotson (or maybe just took some training course), there's no doubt it
    would have saved us thousands of dollars. It might have saved a few years
    of my life also not stressing to learn it the hard way. But, I've found my
    boss loves setting people up for failure and watching them struggle. I
    guess it makes him feel adequate.
    Distinguished Contributor
    01-25-2007 12:13 PM in reply to: *Russ
    That part you were replying to applies to everything here, not just inventor. But I appreciate your good faith.
    01-25-2007 01:13 PM in reply to: *Russ
    >On the other hand, it's also possible to build assemblies
    that are nearly bulletproof.
    Does this require the Kevlar add-in? :-)
    Active Member
    mikevick
    01-21-2011 01:34 AM in reply to: *Russ
    Hi This may seem like a stupid question but im moving over from solidworks back to inventor for the first time in four years and im just trying to get my head around some things. On a sketch if i draw a rectangle and stick a construction line from corner to corner i can't constrain the midpoint of that construction line to the origin. why is this? is there a setting i need to turn on in application settings?
    Active Member
    mikevick
    01-21-2011 04:00 AM in reply to: mikevick
    Its ok i found out you project geometry of the origin/center point when you start a drawing and then constrain to that. If there is a way to set this before hand please feel free to add
    01-21-2011 07:34 AM in reply to: mikevick
    Uhhmm, what version of Inventor are you using. (that has been the default behavior for years)  You might want to read these documents
    newer
    http://home.pct.edu/~jmather/skillsusa%20university.pdf
    older
    http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf
    Inventor Professional 2014 Edu 64-bit
