• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Complex Lofting Question
    118 Views, 22 Replies
    12-05-2002 04:13 AM
    I have a need to form what is known as a Francis vane impeller (double curvature). Lucky me, huh? Anyway, I understand the loft method for generating a shape from multiple planar sketches, but how on earth can you generate a 3D sketch on a non-planar surface??? As far as I can tell, 3D sketch is only for sweeps. A couple of good similar examples of what I'm trying to do would be either a propeller for a airplane or a boat if you were trying to do the lofting outward, STARTING (I repeat - STARTING) from the hub surface which for both of these objects are curves....Thanks in advance.
    Troy Zellers
    Please use plain text.
    Member
    Re: Complex Lofting Question
    12-05-2002 04:27 AM in reply to: HomeMadeSin
    Though probably not identical to your design, the Autodesk Inventor 5 Essentials Courseware has an example of creating a fan blade using the loft feature. See Chapter 7 (7-5 through 7-9
    *Caldwell, Larry
    12-05-2002 05:02 AM in reply to: HomeMadeSin
    Centrifugal pump. eh? You have a profile of the
    shape or a way to determine it? If you want to email me the profile, I'll give
    it a shot.
    Larry
    I
    Troy Zellers
    Valued Contributor
    Re:
    12-05-2002 06:02 AM in reply to: HomeMadeSin
    Yeah. It is easy to be impressed with the simple lofts and extrusions, etc when they demonstrate the software. I was. But I have yet to see the complex shapes of pumps, turbines, etc easily demonstrated.
    As it stands right now, I only have the profile of the bottom edge of the vane,not the top. I was trying to see if I could project the 2D profile onto the curved impeller shroud first. If I could do that, then I could do the same on the other shroud and have two non-planar (or 3D) "sketches" to serve as the beginning and terminating loft points.
    I'm having to scan the original hand-drawn drawing, convert to vector, import into AutoCAD and re-trace via polylines and then import the AutoCAD profile into Inventor. I'm sure there is an easier way, but I haven't found one yet.
    *Costan, Tom
    12-05-2002 06:10 AM in reply to: HomeMadeSin
    Search customer files for this example.  An
    excellent treatment on lofting.
    size=2>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
    Newsgroups: autodesk.autocad.customer-files
    Sent: Thursday, October 24, 2002 7:06 PM
    Subject: Propeller R6 update
    Here's that prop Kent. I updated (re-drew) it in
    R6.
    ~Larry
    size=2><<<<<<<<<<<<<<<<<<<<<<<<<<<
    -tom
    I
    Troy Zellers
    Valued Contributor
    Re:
    12-05-2002 07:10 AM in reply to: HomeMadeSin
    Pardon the dumb question, but is there a way to get to the customer files in www mode? I used to do all newsgroup, but had problems with the laptop had to reformat a few times. So I've procrastinated in setting it back up. Besides, I haven't figured out newsgroups from behind a firewall at work so I have to do them after hours via dial-up (yuk).
    Valued Contributor
    Re:
    12-05-2002 07:14 AM in reply to: HomeMadeSin
    Duhhhhh. Nevermind, I found it. sorry.
    Valued Contributor
    Re:
    12-05-2002 07:28 AM in reply to: HomeMadeSin
    Ok. I found the file and downloaded it. I agree it is a excellent treatment of lofting, however, all of the sketches are planar. This is easy. I'm talking about establishing a sketch ON A CURVED surface and using it as loft ...er plane..
    Any ideas?
    *Costan, Tom
    Re:
    12-05-2002 08:39 AM in reply to: HomeMadeSin
    All sketches in IV are going to be planar. (at
    least in my experience)  I'm not sure about the new
    surface capabilities of IV6; maybe something to look at there.  I
    suggested the propblade because it seemed to have some unique lofting.
    More food for thought than an exact example.  I could  have
    been more specific.
    I have allways used planar profiles on our fan
    blades and  I'am constanly repeating to my self, "it's only a
    fan".
    As a possibility - MDTs surfacing and stitching if
    you have the patience.
    -Tom
    Ok.
    plane..
    Any ideas?
    Valued Contributor
    Re:
    12-05-2002 11:54 AM in reply to: HomeMadeSin
    Thanks Tom.
    Frankly, this is one of my fears (that Inventor isn't set-up - yet - to do this type of feature). I just couldn't face learning P/E. Besides, at another pump manufacturer, the P/E guys didn't tackle this issue either - they "faked" it for visual purposes, not actual dimensions.
    I would try MDT.....something else to learn.
    Troy Zellers
