• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    exSWX
    Accepted Solution
    Collapse All Children-IV2013
    213 Views, 4 Replies
    10-23-2012 02:12 PM
    Is the Collapse All Children in the Feature Tree only available in Part Environment?
    Autodesk Inventor 2013-64Bit Edition
    Intel Xeon W3520 @ 2.67GHz
    Win 7 Pro
    6.7 System Rating
    NVIDIA Quadro FX 1800
    Please use plain text.
    Employee
    MingweiGao
    Re: Collapse All Children-IV2013
    10-23-2012 07:14 PM in reply to: exSWX
    No, this functionality also availble for an assembly or sub-assembly.
    Mingwei Gao
    Software QA Engineer
    Inventor Quality Assurance Team
    Active Contributor
    exSWX
    10-24-2012 03:36 PM in reply to: MingweiGao
    Thank you for your most detailed response :smileyfrustrated:
    Would you care to explain how I use this function in the Assembly or Sub-Assembly environment?
    In the Part Environment, I can RMB and Collapse all Children. In the Assembly Envirinment, if I RMB on the feature tree, I do not get the option to Collapse all Children.
    Win 7 Pro
    6.7 System Rating
    Employee
    MingweiGao
    10-24-2012 06:55 PM in reply to: exSWX
    Hi, do you want to collapse/expand all features of each part? If yes, you need to change the view from Assembly View to Modeling View. Please refer to the attached picture for the details. For assembly view, there is the Collapse All Children command when you RMB on the top assembly or sub assembly browser node. If not, can you give us more details of your requirement?
    Mingwei Gao
    Active Contributor
    exSWX
    10-25-2012 03:15 PM in reply to: MingweiGao
    Thanks you for your informative response :smileyhappy:
    Win 7 Pro
    6.7 System Rating
