• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Coding in Inventor (iLogic) - Measure an angle
    286 Views, 6 Replies
    12-13-2012 11:11 AM
    How do I measue angles between faces in a rule? I want to create a simple if statment depending on the angle between a rotating object and a grounded object. If a certain face of the rotating object is 180 degrees relative a face on the fixated object the rotating object is supposed to rotate around its own axis.
    I've seen the Measure.Angle-function but I can't get it to work.
    Thanks!
    Please use plain text.
    *Pro
    jletcher
    Re: Coding in Inventor (iLogic) - Measure an angle
    12-13-2012 11:31 AM in reply to: eric.vinjegaard
    Does it have to be a dimension? are you in an assembly?
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    Active Member
    12-13-2012 11:40 AM in reply to: jletcher
    Yes, it´s in an assembly.
    Well i I just want the rule to measue the angle between the two faces (two different parts) each time the rule iterates to determine the state of the rotating object. As I mentioned before, the rotating objects' angle relative the ground is supposed to be determined depending on the angle between two faces.
    *Pro
    jletcher
    12-13-2012 11:43 AM in reply to: eric.vinjegaard
    How are you controlling the angle?
    James Letcher
    Active Member
    12-13-2012 11:53 AM in reply to: jletcher
    It is constrained on another object which is rotating and the rotating movement is controlled with an angle parameter.
    I simply want a rule to measure an angle between two faces on its own to launch different actions depending on that angle.
    *Pro
    jletcher
    12-13-2012 11:54 AM in reply to: eric.vinjegaard
    Just have the rule read the parameter not a dimension..
    James Letcher
    Active Member
    12-13-2012 12:04 PM in reply to: jletcher
    That´s what I've been doing but I realized that it's not a good way to go. I'm driving the constraint (parameter) now to make the movements the way I want them to be, but later on when I'm going to do simulations the parameter is not going to be the reason the object is rotating. But if i manage to measure the angle between the objects within the code I will be able to determine its position. Do you know if it's possible to do that?
