• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Classic UI in Inventor 2012??
    2838 Views, 7 Replies
    07-04-2011 09:35 PM
    My computer got stuck while working in Design Assistant 2012 (AutocadM 2012, Inv 2012, Excel 2010 and Outlook 2010 were also open). I had to hard reset and restart. After restarting opened AutocadM and Inventor at the same time. Opened Design Assistant 2012 and found some files needs migration. closed Inv and opened Tak Scheduler. Converted files. Opend Inventor. Voila, Inventor opened in Classic UI. See attached screen captures.
    Any comments from anyone else? This is a new PC with Win 7 64bit and Office 2010. No previous version of Autodesk software on it.
    Autodesk Product Design Suite Premium 2013
    Microsoft Windows 7 Professional 64bit SP1
    Gigabyte P67A-UD3R-B3, Core i7-2600K CPU
    8.00GB DDR3, NVIDIA Quadro 2000
    Please use plain text.
    blair
    Re: Classic UI in Inventor 2012??
    07-04-2011 11:06 PM in reply to: binuvarkey
    Sweet!
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.0 / 4.11
    Product Support
    alessandro.gasso
    07-05-2011 01:36 AM in reply to: binuvarkey
    This can happen when the Task Scheduler process itself crashes or got terminated in the middle of finishing a task.
    After that, the next Inventor session will be set to Classic UI.
    By the way, if you set back the Ribbon UI, in the Application Options, Colors tab, Interface Style and restart Inventor, you should get the Ribbon back (but, I’m sure you’ve already done it).
    Kind regards,
    Alessandro
    Alessandro Gasso
    Product Support Technical Lead
    MFG - Inventor
    Active Contributor
    johan.max
    07-05-2011 01:59 AM in reply to: binuvarkey
    Yes you can add it in regedit too pop up classic interface in Options tab HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion16.0\System\Preferences\UIStyle InterfaceStyle =1 Johan
    Active Contributor
    johan.max
    07-05-2011 02:02 AM in reply to: alessandro.gasso
    Why can we not comments in blogg http://beinginventive.typepad.com alessandro good tups on the blogg. Johan
    Product Support
    alessandro.gasso
    07-05-2011 02:28 AM in reply to: johan.max
    Hi Johan,
    I’m not sure I got your last comment.
    Is it related to this post or to the Blog in general?
    Thanks and regards,
    Alessandro
    Alessandro Gasso
    MFG - Inventor
    Active Contributor
    johan.max
    07-05-2011 02:45 AM in reply to: alessandro.gasso
    To the Blog in general http://beinginventive.typepad.com (This was the way to contact you ....to say it .....) Johan
    Product Support
    alessandro.gasso
    07-05-2011 02:49 AM in reply to: johan.max
    Ok, got it!
    I’ll report the problem to the site administrator asking for fixing the problem.
    I apologize with the others involved in this post that are receiving notifications unrelated with the topic of the post.
    Thanks and regards,
    Alessandro
    Alessandro Gasso
    MFG - Inventor
