• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Bliss, Charles
    Cinepak Codec by Radius
    627 Views, 4 Replies
    11-20-2002 12:15 PM
    Since I can no longer specify the codec for recording in R6, perhaps
    someone knows where the default codec is set? On my PC, Inventor seems
    to be exporting to the "Cinepak Codec by Radius". Wasn't Radius the MAC
    video company (with financial problems)?
    Seems to me that there should be a means of setting up this default.
    When Autodesk goes to "fix" this, I would also like to see a better
    means of setting up the output frame rate. Another input box in the
    animation and drive constraint dialogs would suffice.
    It is currently defaulting to 15 fps which is not what I want either. I
    have always liked the concept of being able to set the frame rate myself
    so I can end up with a mathematically predictable animation. Currently
    I post process all my animations which can become a bit tedious.
    Please use plain text.
    *Dotson, Sean
    Re: Cinepak Codec by Radius
    11-20-2002 12:52 PM in reply to: *Bliss, Charles
    Charles I was told that Cinepac is indeed the default codec.
    "Charles Bliss" wrote in message
    news:3DDC5DD6.1090303@cbliss.com...
    *Bliss, Charles
    Re:
    11-20-2002 02:37 PM in reply to: *Bliss, Charles
    Yes, I figured that out but is there a way of changing it? I looked in
    the registry and on the Microsoft site. Near as I can tell, it is the
    default because it starts with the letter C and all the rest use higher
    letters in the alphabet. If this is the case, then I would need to
    delete all except the one I want because it is the last on the list.
    (TechSmith / Camtasia)
    To make it more interesting, I just got TechSmith signed off as a
    standard for our company (no small feat) and now Inventor can't use it.
    Doh!
    *Bilton, John
    Re:
    11-20-2002 07:46 PM in reply to: *Bliss, Charles
    Control Panel -> Multimedia -> Hardware ->Video Codecs ->Properties -> Properties delete all except
    TSCC.
    (You already new that though )
    John Bilton
    *Dotson, Sean
    Re:
    11-20-2002 08:16 PM in reply to: *Bliss, Charles
    Sorry didn't read close enough. Hopefully John's suggestion will make this
    work. I'm a bit bummed about this change too. Let me know if you have
    agonizing slow record times.
    -Sean
    news:3DDC7F26.60706@cbliss.com...
    > Doh!
