• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Cinepak Codec by Radius for Inventor Studio 2012
    170 Views, 0 Replies
    12-19-2012 05:11 AM
    Hi
    I recently upgraded my Inventor from 2009 to 2012. At the moment I am working on a series of animations. Before the upgrade I used to render my animations with the Cineak Codec be Radius. It worked fine as it didn't create huge files as the other codecs did (the others would typically create a 1 GB file from a 40 second movie).
    Now after the upgrade, I do not have the option to render using the same codec. It is simply not there. The other options is:
    • Full frames (Uncompressed)
    • Intel IYUV codec
    • Intel IYUV codec (yes, there is two instances of this one).
    • Microsoft Video 1
    But as mentioned, the fifth option is missing.
    Does anyone know if it is possible to retrieve this, or if not, is there an alternative?
    Please use plain text.
